Full charge indicated e mileage
Discussion in 'Prime Fuel Economy & EV Range' started by marcoinpb, Apr 3, 2019.
Tags:
  1. marcoinpb
    marcoinpb Member
    64
    27
    2018 Prius Prime
    36.5 this morning indicates for none A/C use. Usually around 32 for full charge. I have no clear idea what causes the variable. And as many have noted, the lack of a miles drive on battery generated by Prime is not helpful or rational.
    51,523
    too many variables, it's all guess work.
  3. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Multiple by 0.76852
    Rob43
  4. marcoinpb
    marcoinpb Member
    64
    27
    2018 Prius Prime
    Multiple by 0.76852
    Was that intended as a joke?
  5. bisco
    51,523
    yes. unfortunately, there is no clear answer to your problem, as you can see by others who have posted similar.
    if you give us more details, we can take some educated guesses, but no one knows for sure except toyota, and they aren't talking.
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Capture.JPG Over a month or two the Prime "learns" your EV driving habits. Excerpt from owner's manual:
  7. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Yep, like stated above, there's no clear answer to your problem. The computer tries to take a guess at it, but it's a guess at best, and if you change your driving habits; the calculation changes.
    Rob43
  8. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The computer is guessing based on past history. The only way to know if it's accurate is to drive until you run out of EV and see how many miles you went.
    jerrymildred likes this.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Mine increased from 25 to 30 miles, I don't know that it was related to the warming weather or the car figured out I am anal about saving fuel of either type.
  10. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    Lucky you! Mine still have not reached back to 30 miles EV range on the GOM. The morning temperature still hovering around freezing mark, my A/C ratio is still too high. Today was 27.4 miles. A few more weeks, I hope.
  11. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    I think it is based on your E-mileage during your last few trips.
  12. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    A/C ratio??? Mine is pretty much always 0%. But then I do (most of the time) have the advantage of waiting until the temp has risen some for the day before I drive anywhere. The GOM said 30.8 this afternoon, it was 41°F and raining. I did "precondition" the car while it was plugged in, then turned off the climate system when I started out. Made 2 stops, didn't need gloves today but did have my winter coat on.
  13. Salamander_King
    11,010
    8,940
    New England
    I leave my home at 6 am and our morning temp is still below freezing. Just for the morning commute 18 miles, I use up most of the EV range. The afternoon temp is getting mild and I have no heat or AC on, but not enough EV range left to get back home. :cry::cry::cry:
  14. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Perhaps if you ran part of the morning run on HV, you can use the engine where it is efficient, and reserve the EV capacity for the rest of the trip.
  15. Salamander_King
    11,010
    8,940
    New England
    Yeah, that's exactly what I do during winter months. Since at our morning temp, the heat pump is not strong enough, ICE comes on most of the morning commute no matter what I do. For those days, I usually drive HV in the morning, and keep the cabin warm, and save all EV range for the commute back home. I can certainly do the same thing all year long, but switching between HV and EV makes impossible to record the actual miles driven on EV. For now, I am recording spring EV drive ranges by using all the battery capacity until it runs out and taking note of distance it runs until HV comes on.
