Hybrid Battery Needs Replacing - time to sell?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ktea, Apr 4, 2019.
  1. Tow to dealer & sell
    0 vote(s)
    0.0%
  2. Tow to mechanic & replace battery
    100.0%
  1. Ktea
    Ktea New Member
    Seattle, WA
    My husband's 2007 has 106,000 miles, and we live in a state w/out extended battery warranty. Sad trombone.
    Ran error codes at auto parts place and he needs to tow it to dealer/mechanic, so we need to decide ASAP whether to replace the battery or the car. Kelly Blue book says it is worth ~ $5k, waiting for quote on battery but we expect it will be about half that.
    Can anyone share the major costs associated with a Prius over 100K miles? It has been well maintained (he is original owner), but at some point the transmission will go, right? There will be some major repairs needed in the future, but we have not owned a car long enough to know what those might be. And while he replaces bulbs and filters, neither of us can do major work on cars.
    Should we expect to shell out big $ in the next few years, in which case it's time for a different car? Or can he expect to drive less than 10K miles for a few years without big trouble? What has been your experience?
    Thanks so much for your help!!!!
  2. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    A Prius does not have a transmission in the sense that you perceive. Go with Factory new or 2k1toaster battery.
  3. Ktea
    Ktea New Member
    Seattle, WA
    Thanks, Skibob - that's where we're leaning. Quote is $3,400-$3,900. Dealer & mechanic said maintenance for the next few years shouldn't be bad, but the warranty on the new battery is just 3 years.
    Currently looking at the safety features on the 2019 Prius since our oldest is 14 and he will likely be driving this car - that plus spending 1/5 of a new car on a battery does give us pause.
  4. Skibob
    2,912
    1,502
    Northern California
    It’s only 1 year warranty if you or a non dealer shop installs it. The battery is not that much and an independent shop can install it for much less. My guess is low 2000’s is the real price non dealer. The dealer just wants to sell you a new car, give you 1000 bucks for the old one then throw in a new battery and sell yours for 6,7 thousand.
    srellim234 and Merkey like this.
  5. Ktea
    Ktea New Member
    Seattle, WA
    Independent shop quoted $3,700. I don't know if it is just the market we are in (Seattle) or what, but our usual shop doesn't do the Prius battery. We haven't mentioned the possibility of buying a new car to the dealer yet, but I bet you are right about what they'd give us - and then sell it for.
  6. Skibob
    2,912
    1,502
    Northern California
    Post a request for reliable independent shops in the Seattle area and see what comes up.
  7. Skibob
    2,912
    1,502
    Northern California
    Sorry do this in the newb section not the gen 2 section. More people will see it.
  8. bisco
    51,843
    get the $1,600. 2k1 new battery if you can find a place to install it. if you can find a decent hybrid shop, your next major expenses could be the brake actuator and a/c compressor
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The problem is that the hybrid battery as of January of last year dropped way in price if you've got an in with Toyota. Independent mechanics that compete with the dealership for their bread and butter pay retail. Independent "hybrid mechanics" that just do battery work, can get a range of prices that span about $500 difference. Mechanic that works for a dealer with a friends and family discount and so on, can get it as cheap as I can sell my packs.
    Shop around to a different dealer if you want OEM battery. Your quote is high for most places in the US, by about $1k.
    If you want to order my kit, there are lots of installers in the area that can do the job if you can't. It's the same work as a mobile battery swap for most of these guys. If you let them keep the old modules sometimes you can get it for free. About a $300 to $500 value, but you then have no "core" to return in the future if you ever need to. Buying junk modules on eBay to swap back in to make a core is an option.
    Spice Nav and srellim234 like this.
  10. chelvis
    chelvis Member
    84
    49
    Long Valley, NJ
    Welcome Ktea. I have a 2005, bought it new and currently have 303K miles on it. I had no real big maintenance costs before or past 100K miles. New struts and shocks but I didn't do those until after 200K. "Transmission" has been steady, changed fluid initially at 100K and have doing it every 60K ever since.
    10K miles a year is not a lot (to me anyway;)). My experience would suggest you should be ok.
    Recommend a new battery either 2K1Toaster cells or new OEM Toyota. Car mileage is low, how's the engine? Does it consume oil? If not, very good for you. I just replaced my battery last year @ 288K miles from a member here (TMR-JWAP) who puts together battery packs with newer cells...unfortunately he is here on the East Coast :(
  11. Philhave
    Philhave Junior Member
    Chicago
    2008 Prius in Chicago area. Think batteries need to be rebuilt or replaced. Aux battery is 2 y.o. Tried to jump start- no go.
    Still have $2k left to pay. Suggestions on local person to replace or rebuild batteries. Thank you!
  12. bisco
    51,843
    don't jump the gun, test the 12v.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Jump start has nothing to do with the main battery. There are tons of vehicles less than 2 years old sitting in junkyards. Age by itself means absolutely nothing. If on Day1 you let it sit and drained the battery, then your 1 day old aux battery would need to be replaced.
    Be more specific about what you did and what happened or didn't happen and people might be able to offer advise other than guessing.
  14. Sue Wyand
    Sue Wyand New Member
    Chicago
    Looking for someone to help replace a battery on my son’s 2007 Prius. Would like to get a rebuilt one for his car in the Chicago area.
  15. bisco
    51,843
    there are lots of places, but be aware that rebuilt batteries aren't always reliable: chicago
  16. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
