Crash-Test Credentials Come Standard on 2019 Toyota Prius, Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Apr 2, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Mark57 likes this.
  2. Marine Ray
    1,139
    947
    Sparks, NV
  3. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    the Prius and Prius Prime missed out on the higher Top Safety Pick Plus award because of their headlight ratings.
    I wish they went into the nitty gritty details. A few words summarizing the ranking didn't satisfy my curiosity much.
    I wonder if there's any YouTube videos about it
  4. Marine Ray
    1,139
    947
    Sparks, NV
    Here's nitty gritty from IIHS. Looks like headlights were inadequate on left curves:
  5. Marine Ray
    1,139
    947
    Sparks, NV
    Here's link to full IIHS report:
  6. Prodigyplace
    12,551
    11,772
    Central Virginia
    The details are here.
    2019 Toyota Prius
  7. Marine Ray
    1,139
    947
    Sparks, NV
    Thx. I was having problems posting links.
    Prodigyplace likes this.
  8. Prodigyplace
    12,551
    11,772
    Central Virginia
  9. lllars
    lllars Junior Member
    32
    Southern Vermont
    2018 Prius Prime
    Is it possible to adjust the aim of headlights to improve the left side illumination distance? Maybe it just needs to be tilted up a bit?
  10. Prodigyplace
    12,551
    11,772
    Central Virginia
    I do not know. Perhaps consult your firestarter user manual.
  11. lllars
    32
    Southern Vermont
    2018 Prius Prime
    The manual is not much help (see below). Really what would be interesting to know is if the problem is that the left headlamp is aimed too low from the factory. Perhaps there is room to aim it up a bit without blinding oncoming drivers.
    According to pages 637 & 638 of the manual, there are 2 vertical adjustment knobs per headlight which should be turned the same amount whenever a change is made. There is no specification given for how high to aim the headlights. I wonder what part of the headlight each knob corresponds to. Is one for the low beams and one for the high?
  12. Prodigyplace
    12,551
    11,772
    Central Virginia
    left & right ides f the light? I expect your car, like my Gen 4 uses shutters to change between low & high beams.
    If it is still under warranty, the dealer should be able to check & aim if necessary.
