Traction battery fan filter
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by rosencrantz, Nov 7, 2018.
  1. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    well I was looking at the inlet to the fan for hv battery. I ended up removing the cover and was pleasantly surprised to see a replaceable filter for the fan. Even better, it appears that there’s easy access to the fan itself - if cleaning the blades became necessary. I’ve read stories about people adding filter material to earlier Prius.... it’s nice Toyota has finally installed a proper battery filter. I don’t recall seeing a maintenance schedule for it.... did I just miss it?
    51,027
    good question. can you post a pic so we can see what material they are using?
  3. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    And how in the heck did you get that grill off? Mine won't budge. Is the 2018 different from my old '16? :LOL:
  4. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Actually, after posting this thread, I saw a YouTube video that describes replacement. The filter is pretty thin and a bit flimsy.... but appears it’ll do the job.
  5. Mendel Leisk
    40,471
    I would dig down to the fan when you've got a few miles on, to clean it, and to get an idea how often it'll need to be done in future.
    rosencrantz likes this.
  6. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Not sure what the 2016 looks like..... assuming it’s like mine, there’s a single plastic expansion pin. You pull the center part straight out and then pull the remaining plastic capture ring out. I used a jewelers flat blade screw driver to get under the center plastic pin. The rest of the cover is held in place by non-removable clips. With the expansion pin removed, just pull the cover off.
  7. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    Ill have to double check on my 17, but I remember looking at it for 15 minutes, and checking the repair manual, and for some reason I came to the conclusion it was literally impossible to remove.
  8. dald
    dald Junior Member
    sgp
    Does anyone know the part number or where to get replacement filters for the traction battery fan? I've searched the entire forums and can't find d any on these.
    Went in to the dealership for servicing and they said the filter required replacement and wanted to charge $90 for it.
  9. PentastarM
    PentastarM New Member
    Michigan
    2018 Prius
    I got my 2018 Four at the beginning of December at 257 miles and just rolled over 6000 miles this past weekend. Popped the fan cover off and the fan and filter looked pristine.
    Maybe that helps someone make a timing decision. I'll check again at 10000 miles.
    Mendel Leisk and krmcg like this.
  10. Mendel Leisk
    40,471
    Depends on locale, pets in car etc, but that said: 6K miles it should still be very clean. Thanks for the report.
  11. CooCooCaChoo
    CooCooCaChoo Senior Member
    950
    533
    Cow-lee-fornia
    2023 Prius
    Found a video of a guy accessing that filter:
  12. Mendel Leisk
    40,471
    That's the filter not the fan. :confused:
  13. CooCooCaChoo
    950
    533
    Cow-lee-fornia
    2023 Prius
    Yeah, we're talking about the filter :/
  14. Mendel Leisk
    40,471
    True, missed that. I guess the guy who made the video should fix the title though.
  15. Elt31987
    Elt31987 Active Member
    205
    154
    Derry, NH
    Just pulled mine 10 minutes ago. At 69,000 miles the filter was packed. I used my DataVac to blow all of the dust and hair out of it. HIGHLY recommend you clean it every 30K or so. I tried finding the part number for the filter or even the door itself but cant find either on my dealers part lists. I at least got the filter cleaned out well, but i'm the type to pay 10 bucks for a brand new filter instead of cleaning it. The fan itself had little to no dust on it though.
    IMG_20190413_142603.jpg IMG_20190413_142610.jpg IMG_20190413_142616.jpg IMG_20190413_143509.jpg
    Storm88000, PtPri, krmcg and 3 others like this.
  16. krmcg
    2,592
    2,391
    Whittier, CA
    I guess I'll have to check mine now...
    Elt31987 likes this.
  17. krmcg
    2,592
    2,391
    Whittier, CA
    Well, I checked mine. At first glance I thought that it was really, really dirty. But, it turns out the filter element is charcoal gray and is pristine!
  18. Elt31987
    205
    154
    Derry, NH
    Wow, surprised there was nothing in between the pleats. Guess my 4 year old causes more of a mess than I thought lol
    krmcg likes this.
  19. dald
    dald Junior Member
    sgp
    Just pulled mine out too. Bad a little trouble with the cross tip screw.
    I live in a city so city only driving. 53k Kms and it was pretty dusty. Dealer wanted to charge me 90 dollars to replace this.
    PtPri and Elt31987 like this.
  20. Elt31987
    205
    154
    Derry, NH
    Yeah thats about what mine looked like. I cant find the model number anywhere. Cleaning out should definitely help prolong the battery until someone can find a replacement filter. If they are like 10 bucks ill just replace em every 30K
