My car is shooting out cyl 1 codes (p301) sometimes engine bucks when starting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rrrolfff, Apr 18, 2019.
  1. Rrrolfff
    Rrrolfff Junior Member
    77
    Irvine
    All of the sudden im getting bucking engine. Once its running fine for many miles. Sometimes, ill sit, and when it starts, the engine seems to jump a bit. I give gas, alls fine. Get a check engine that basically say cyl 1 is having issues (gas etc). Im in so cal - seems hardware (engine) related. Could be gas, but it seems a physical thing. Any ideas or recomendations? TIA!
  2. Rrrolfff
    77
    Irvine
    Coolant level is fine. Been foing this a day since driving on vertcle streets in LA... egr? Only one cylendar (1)...
  3. Rrrolfff
    77
    Irvine
    On pretty flat ground, it starts bucking - keeps it up even if i give gas - until i pit it in gear, works great as long as iys in gear....
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Plugs,coil,or egr circuit clogged
  5. orenji
    orenji Senior Member
    5,887
    3,488
    How many miles?
  6. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Clean intake manifold, clean or change plugs, bad coil. Install occ. Maybe rats chewed some wires???
