A hybrid Filter at 50,000?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by icyrius, Sep 2, 2017.
  1. mikefocke
    3,886
    1,749
    Sanford, NC
    By this time with hybrid battery cooling experience and knowing it to be a potential issue, why wouldn't Toyota make it an easy to access maintenance item?
    51,029
    things that make you go hmmm....
  3. Mendel Leisk
    40,472
    Lack of foresight? You can put the EGR in the same category methinks.
  4. Mendel Leisk
    40,472
    And headlight bulbs...
    And spark plugs...
  5. Analogkid1958
    Analogkid1958 Member
    119
    61
    Yorktown, IN
    2024 Prius
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    There's alarms and error codes that erupt if the traction battery gets even a little hot. Not to mention the fan cavitating and blowing at max RPM. Its not something you can easily ignore. I'm surprised this dealer didn't insist on doing a TB and injector flush. ;)
  7. bisco
    51,029
    aren't spark plugs in there at 120k? i wouldn't expect bulbs to be a regular maintenance item, fix when broken.
  8. Mendel Leisk
    40,472
    You're right. I'm just thinking of the items that are inordinately hard to access.
    Analogkid1958 and bisco like this.
  9. bisco
    51,029
    there once was a car with a transverse mounted engine, with the plugs so close to the firewall, you had to remove the engine mounts and move it, iirc.
  10. Mendel Leisk
    40,472
    I think the timing chain cover reseal almost requires engine removal. Done with the engine in place it's almost impossible to do it right.
  11. bisco
    51,029
    which would be fine, if they didn't leak prematurely.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I watched a very interesting (to me) documentary called " A Faster Horse " about the designing, building and release of a new Ford Mustang.
    One of the things I took from the documentary, is while "We" may not notice a change, or look at an item and think a change is minor, every change to a designed automobile can have a unexpected ripple effect through the whole design.
    So we can look at the fan set up and say "Why isn't it designed to be accessed better?". But depending on where a car is at in design and production, even a seemingly minor change like that, could be much more challenging than originally thought.
  13. HybridMotorWorks831
    HybridMotorWorks831 New Member
    Salinas, Ca
    The main time I see this is on the 'prius c'. And i just use a little loop of duct tape and stick it on the 'dryer lint' looking buildup on the screen. Takes under 1 minute if you have ever done it before.
    300 bucks?
  14. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    And the all important wallet flush!
  15. camp1019
    camp1019 New Member
    Los Angeles
    2015 Prius v wagon
    No need to buy a new filter unless the mesh on the old one is damaged. It can be easily cleaned.
  16. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    I'd like to clean the filter in my 2010. Can anyone give me tips on that? The NutsAboutBolts video looked like it was for cleaning the fan.
  17. bisco
    51,029
    you just pry off the grill
  18. mikey_t
    370
    391
    Los Angeles
    Ah OK, thanks.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    You have a filter for your hv battery?
    They didn’t come standard until I believe 2012.
  20. mikey_t
    370
    391
    Los Angeles
    I think so. I was at the dealership this morning for a fuel injector cleaning service and they recommended the fan cleaning and filter change. I think the fan was cleaned when I got my battery replaced, but I'd like to check out the filter myself (if there is one). I was just in my car trying to pry it off but I felt like I was going to break something so I'll go back to it later.
    Raytheeagle likes this.
