Should the charcoal filter, on the bottom of the lid of the airfilter box, be changed after 11 years
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 25, 2019.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    My Prius is a 2008
    Should the charcoal filter, on the bottom of the lid of the airfilter box, be changed after 11 years?
  2. Leadfoot J. McCoalroller
    8,071
    7,552
    Pennsylvania
    2018 Prius c
    Should not be any need unless it's somehow been damaged.
    Its job is to absorb gasoline vapors that have made it up the intake manifold from the injectors after you shut down. It temporarily holds those vapors, and then they get pulled back into the engine on the next startup cycle.
    It can repeat that absorption/flush cycle forever, as long as it doesn't get damaged in a crash or eaten by a rodent or something.
    SFO and Data Daedalus like this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    They could in theory become over saturated from gas vapors, just like fuel tank canisters sometimes do. The way to counter that would be to bake the VOC’s out of it. That would work but your oven would stink like gasoline.
    Data Daedalus likes this.
  4. Leadfoot J. McCoalroller
    8,071
    7,552
    Pennsylvania
    2018 Prius c
    What, you don't think it gets baked enough in a plastic box next to a hot engine whilst dry air is drawn over it?
    edthefox5 likes this.
  5. Skibob
    2,912
    1,502
    Northern California
    Not sure. When the engine is running it gets outside air drawn through the air filter. I’m talking about 200 degrees for an hour
  6. Stevewoods
    Stevewoods Senior Member
    659
    1,125
    Seattle, WA
    You are embarking on this journey again? Hmm. Good luck. Watch out for rattlers and cougars.
    cyberpriusII and Skibob like this.
  7. Skibob
    2,912
    1,502
    Northern California
    Guess he’s moved on from transmission fluid. :whistle:
    edthefox5 and cyberpriusII like this.
  8. bisco
    51,843
    no
    cyberpriusII likes this.
  9. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Hate to poke a slumbering troll, but if anyone seriously thought this was an issue, would not the dealers be pushing it everytime a Prius was brought in for service?
    EVERY time I take mine in, they try to sell me a cabin filter and engine air filter. Everytime I tell them I just checked them and they are fine...if it was at all an issue I am sure the dealers would be touting replacements -- sort of surprised they do not tout new windshields every five years.
    don_chuwish, SFO and Skibob like this.
  10. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Wonder if the service guys even know about it? (Possible reason they aren’t pushing replacement). Probably only California, and possibly the other CARB adopting states, cares about whether it’s functioning/or even there. It’s due to that darn carbon thing no aftermarket air intakes receive CARB EO #s. (Sucks)!
    (Trying to avoid reading ATF threads now)....
  11. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Er, I would be very reluctant to bake VOCs out in an electric oven, and in a gas-fired oven I think the explosion danger would be quite high.
    (Worked in the safety domain and can’t shake that mind set.)
  12. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I’ve read very unhealthy to breathe gas fumes. Gulp, in a food producing appliance...
    No, no need to change, unless physically damaged as mentioned, my opinion....
  13. Skibob
    2,912
    1,502
    Northern California
    If I ever did it I would use my friends lab oven in his garage. Way better temperature control.
