Dealer fuel induction service same as EGR cleaning?
Discussion in 'Gen 3 Prius Fuel Economy' started by MegaPrius101, Apr 30, 2019.
  1. MegaPrius101
    MegaPrius101 Junior Member
    57
    31
    I
    hey everyone .. so I’ve been reading up on the EGR cleaning to improve gas mileage. I’ve asked 3 Toyota dealers about this and 1 didn’t do any type of service involving that and the other 2 recommended a “fuel induction” service where they inject some type of fluid into engine and let it clean it out. I asked if any parts are removed from engine and they said no..
    Is the EGR cleaning and fuel induction service the same?
    If I can’t find a dealer or independent mechanic that can do this for me , I’m going to attempt it myself.
  2. Grit
    Grit Senior Member
    6,566
    4,223
    Wilkes Land
    It’s just them pouring fuel system cleaner or fuel injector cleaner in the fuel tank.
    Raytheeagle likes this.
  3. Leadfoot J. McCoalroller
    8,004
    7,477
    Pennsylvania
    2018 Prius c
    Not even close.
    They attempt to clean the fuel system with a chemical additive. Sometimes this is effective, sometimes it is actually beneficial. If you are in the habit of buying fuel from big oil brand gas stations, you probably don't need this- they are already blending enough detergent into your fuel.
    EGR cleaning is completely different.
  4. Mendel Leisk
    40,964
    I doubt that very much, they're not that ballsy. They'll likely hook up a bottle of something, introduce it into the air flow, get an impressive cloud of junk coming out of the tail pipe.
    But no, it's definitely not EGR cleaning. I get the sense they're not to keen on that either, just like Toyota corporate.
    mikey_t and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,516
    Bay Area, California
    2019 Prius Prime
    If their service Bay is out of sight of the customer lounge area, you’d be surprised what they do;).
    Trust them as far as you can heave them(y).
  6. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I recently had this service and my dealership guy said they removed the cylinders and cleaned them up. Though when I asked if they could replace the IM gasket for me the quote was ridiculous, and he said it wasn't removed during the process of fuel induction cleaning and cleaning the fuel injectors. This confused me since I thought the intake openings would be physically cleaned in this process.
  7. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    His lips were moving, so it’s understandable to be confused ;).
    He only knows what the one with the boat payments tells him and can’t go outside the script (y).
    mikey_t likes this.
  8. bettergolf
    bettergolf Active Member
    486
    366
    Sanford NC
    Removed the cylinders??? The ones the pistons are in? Really?
    Too funny!
    Grit likes this.
  9. mikey_t
    371
    391
    Los Angeles
    Is the service just a scam then? I read up on it before doing it along with the fuel injector cleaning and it sounded like a good idea. But since I actually saw how dirty the intake openings were when I cleaned my EGR and intake manifold, it really makes me wish I could clean them up.
    Grit and Raytheeagle like this.
  10. mikey_t
    371
    391
    Los Angeles
    Sorry, I'm most likely not remembering correctly and misquoting. He may have said valves.
    Grit likes this.
  11. bettergolf
    486
    366
    Sanford NC
    If he removed you valves, your Intake manifold gasket would have been replaced in the process.
    This is the problem when people don't understand how an engine works. The "service guy" will tell them whatever he wants to.
    Grit likes this.
  12. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    There is such a thing, but the price is not worth the “benefit” or service ;).
    I know BG Products does a fuel induction service at certain dealers and that is the only one I would consider. But even that is pushing it:cool:.
    If pushed / pressured again for this service, ask them for what documented proof exists that what they are about to do works:whistle:.
    I bet they’ll not ask again(y).
    Grit likes this.
  13. mikey_t
    371
    391
    Los Angeles
    Here's a quote from the Toyota dealership packet I have about the recommended service:
    "Utilizing specialized tools, one of our skilled technicians will clean fuel injectors, clean the throttle body, clean the plenum and air-intake, clean intake valves and ports, remove combustion chamber deposits, and correct the balance of fuel and air in the system."
    How are those intake ports cleaned if the intake manifold isn't removed? In one of the NutsAboutBolt videos I recall him showing how to carefully clean the ports and work around the fuel injector tips. I tried it when I had it all open but the sludge was thick and I didn't want to make a mistake.
    And I'll add that my usual guy at the dealership, who I trust, is currently out on paternity leave. The guy I spoke with recently looked rather young and new.
  14. mikey_t
    371
    391
    Los Angeles
    My car did feel a lot smoother afterwards, though. But honestly I did it b/c I thought they'd clean those ports, and it seemed to make sense if the fuel injectors were cleaned.
  15. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    Be from Missouri: Show me:).
    What they do is spray chemistry down the throttle body and it travels to the intake ports;).
    But ask them for before and after pics so you can see the benefit and I’m sure they’ll decline. Then say if I can’t see the results, how can I trust it was done:cool:.
    Keep going in circles and the dealer should get the idea to move onto the next mark which is probably pulling up at the bay next(y).
    Merkey, Grit and mikey_t like this.
  16. Grit
    Grit Senior Member
    6,566
    4,223
    Wilkes Land
    Defer back to post #7 & #11, I'm glad that you red between the lines in their fine print. Your question above seals it.
  17. Grit
    Grit Senior Member
    6,566
    4,223
    Wilkes Land
    They are. I saw fuel induction cleaning on my prius carfax before buying it. I took the vin number and checked up on the actual chuck patterson toyota where it as maintain, had more detailed info on exact product item number & parts were used to maintain. Sure enough the fuel induction was hyphenated toyota fuel cleaner treatment, it was just a bottle of toyota's own line of ginguine fuel treatment.
