Damage to rear spoiler paint
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by icyrius, Apr 30, 2019.
  1. icyrius
    icyrius Active Member
    238
    113
    Florida, USA
    2014 Prius v wagon
    Any suggestions on how to fix this? I have waxed and polished it 20 times and could not make it look any better. (Please see attached picture)
    Thanks!
    46C06598-5E33-49E8-9BAE-D1F666405E9B.jpeg 7CD0D590-45C8-4753-AC0C-F622B7E48E80.jpeg 7F7799A3-EBAB-4B1D-BD13-3B53129F1138.jpeg
  2. Mendel Leisk
    40,490
    Get a body shop to paint it?
    frodoz737 likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,509
    2,428
    33
    My 2010 faded. Paint or replace is the solution...and it will show all marks if not prepped perfect before paint.
    Raytheeagle likes this.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    The solution is a new spoiler. Around $400 from Toyota.
    Refinishing is not cost effective. A quote to refinish was only $20 less than a new one. At least in my area.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Before we sold our 2010 last weekend, it was showing similar fading:(.
    But it was 10 years old and sits outside at work, so something was going to give:cool:.
    Could have been worse(y).
  6. Mendel Leisk
    40,490
    PlastiDip and call it done?
    Ours has a few war wounds: I've attempted to close the garage door on it two times, maybe three... :oops:
    RMB likes this.
  7. The Critic
    3,193
    2,327
    CA
    Actually, this is what I had in mind:
    Optimum Clear Coat Restorer
    I plan to buy a bottle once it is back in stock and they run their usual 25% off sale. Once the bottle is opened it is only usable for 30 days. So maybe I will see if @raytheeeagle can make arrangements for me to apply it to his recently departed 2010 as well.
    Raytheeagle, Mendel Leisk and icyrius like this.
  8. Grit
    Grit Senior Member
    6,414
    4,181
    Wilkes Land
    Was in a hurry one day at chevron gas station. Wiped a stroke down all the way to the spoiler and left a good streak with the window cleaner scrubber, left marks exactly like the photos. Oh the humanity.
  9. icyrius
    238
    113
    Florida, USA
    2014 Prius v wagon
    This looks simple to apply. I will give it a try. Thanks!
    The Critic likes this.
  10. The Critic
    3,193
    2,327
    CA
    Be sure to clay the surface and polish with a wool pad prior to applying. The surface needs to have some "bite."
  11. Mendel Leisk
    40,490
    Maybe you can get someone like this guy:
    I'm sure for a simple sand and repaint, around $150 CDN? I twigged after watching, this guy's actually in BC, probably greater Van. (Hear the crows??)
    #11 Mendel Leisk, May 1, 2019
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    It's just black paint. Not hard to remove the spoiler. Just paint it yourself. Unless it's a nearly new car, no one will see the difference.
  13. Mendel Leisk
    40,490
    Maybe a hybrid approach: take it off and hand over to a body shop? That should come in under $100.
  14. The Critic
    3,193
    2,327
    CA
    My body shop quoted over $400.
  15. Mendel Leisk
    40,490
    If you bring in the piece?
  16. The Critic
    3,193
    2,327
    CA
    Yes. The labor to remove and reinstall the spoiler is minimal.
    There is paint time and repair time (for prep). Paint and body labor rates are between $75-$90/hr in this area. I think he mentioned needing up to 1.5 hr for repair time alone.
  17. orenji
    orenji Senior Member
    5,886
    3,487
    I just got a quote of $225 if I bring it in.
    marlinsmobile likes this.
  18. Mendel Leisk
    40,490
    They get by mostly on insurance claim jobs? (n)
