Dirty Little Secret -- will install TPMS later???
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, May 1, 2019.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,150
    1,682
    Iowa
    So, am looking at getting dedicated winter tires on wheels for a new Subaru. If I shop locally, I am looking at about the same price as TireRack for the same tire, except local shops will only do it with TPMS. That adds a significant amount of change.
    If I elect TireRack, I can get the same tires -- on actually a better wheel -- for significantly less -- with the cavet that a "local shop" is going to install TPMS on them when I tell the local shop to do it and when I pay the local shop.
    Otherwise the tires will be shipped mounted and balanced to my door, ready to use, except for TPMS. Anyone done this? It seems a bit like rum running, but then again....it is saving me a couple of hundred.....
    51,011
    i have never used tpms, but i do check my pressures regularly.
    i say go for it, is it required in orgon?
    #2 bisco, May 1, 2019
    WilDavis likes this.
  3. cyberpriusII
    1,150
    1,682
    Iowa
    TPMS is required everywhere, sort of, I guess, maybe -- Bob Wilson??
  4. bisco
    51,011
    not according to tire rack, but i don't know how old the google hit is.
  5. bisco
    51,011
    what i can find is: professional shops cannot disable tpms, according to federal law.
  6. cyberpriusII
    1,150
    1,682
    Iowa
    hmm, so maybe I can try to tell the local shop to forget TPMS -- of course, their liability insurance may require them to do it anyway -- but dropping it would drop $200.
    #6 cyberpriusII, May 1, 2019
  7. bisco
    51,011
    yeah, it's not cheap, and it's not very effective imo. at least for toyota, the tire has to be like 10 pounds under before it goes off.
  8. fuzzy1
    10,335
    Based on past threads, it seems that there is no legal problem with you putting non-TPMS wheel assemblies on your car. The only legal problem is for others to do so.
    TireRack's statement that you are expected to go have "local shop" install the TPMS, covers their legal CYA obligations. You are under no legal obligation to follow through with that.
    So this isn't like rum running. As best we know, it is legal for you to make use of the wheels as is. It is your choice, hopefully you know what warning protections you are giving up.
    walterm, Mendel Leisk and PosauneGuy like this.
  9. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    Many here have winter tire mounted without TPMS.
    So in winter they just have the warning light.
    However, some states might require operational TPMS for inspection...Virginia does not.
    As per bisco, it is illegal for shops to disable TPMS on tires which have TPMS.
    In summary, you have to consider Federal law and State Laws, but to my recollection, no one on Prius Chat has ever mentioned that they were forced to put TPMS on snows. A few states definitely want the TPMS operational at inspection.
    #9 wjtracy, May 1, 2019
  10. cyberpriusII
    1,150
    1,682
    Iowa
    So, we do not have inspections, I think we are golden without TPMS, except I did not think about an annoying light being on all winter -- oh,well vs. $200.....
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    …guaranteed to be fixed by the application of a small piece of black Gaffer'sTape (…about ½"x½" should do nicely!)
    Here's my solution:
  12. ETC(SS)
    6,903
    I'm thinking that you have two choices:
    1. Buy and clone a set of sensors for the snows, and have a local shop install them.
    You would indeed be looking at 100-200 bucks for the additional sensors and labor - but then when you do the tire swaps twice a year you won't have that annoying little warning indicator.....or the sticky residue from the tape that you used to cover up the annoying little warning indicator.
    Subaru TPMS cloning - Orange Electronics sensors - Subaru Outback - Subaru Outback Forums
    2. Run the snows sans TPMS.
    This would probably be my approach BUT I live in the deep South, so the only time I have to deal with something snow-related is when all of the Snow-cone trailers start popping up like wildflowers on roadsides and intersections.
    I don't know a lot about Subies, but your annoying little warning indicator may not be a little round icon on your dash, but rather some kind of repeating message on a status screen.
    Also, as mentioned above your state and local government may also have inspections that will incentivize you to put working TPMS sensors on your car, year round.
    The good news is that a separate set of snow tires is a very Subaru thing, and so somebody has already noodled out how to do it for cheap....or whether in the far reaches of the American nor'west...you have to at all.
    Good Luck!
    #12 ETC(SS), May 2, 2019
  13. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    The op is getting scammed by anyone insisting that tpms work, the jobber only has to release the tire or car with tpms if it had it when it entered the shop, the shop can't remove tpms, but if the tire car didn't have it, it doesn't have to have it.
    But, Tpms are 20$, the device to program them is 100$, the device will work for years, not a bad investment.
  14. PosauneGuy
    PosauneGuy Member
    119
    89
    California, here I come...
    2025 Prius
    Agree with fuzzy1 above. I have a set of snow tires for each of my two Prii, and they do not have TPMS. I took the rims to Costco and just told them to mount the new snow tires on the rims, which they did. I can deal with the TPMS light on during the winter months. I don't want the hassle of reprogramming the TPMS system twice a year on two cars.
    fuzzy1, WilDavis and Mendel Leisk like this.
  15. Mendel Leisk
    40,457
    Over eight years back but I still remember, getting snow tires (on Corolla rims) from a local dealership: the guy asks me if I want tpms sensors, while emphatically shaking his head no... ;)
    bisco, fuzzy1 and WilDavis like this.
  16. WilDavis
    2,493
    2,154
    49
    Here in NH, my Gen II gets inspected in June (when the summer wheels (…plus TPMS)) are on. In the winter, the car is wearing its winter wheels (no TPMS) but as I mentioned earlier, I have a set of wireless pressure/temp transducers which go on each set of wheels (see earlier post). I've used them for the past four years and have found them to be very accurate (to within a pound or so of my digital gauge when I check the pressures).
  17. cyberpriusII
    1,150
    1,682
    Iowa
    Talked to local tire shop today. They said if they install the tires/wheels on the car they have to have TPMS. If they mount and balance and toss them into the trunk, no TPMS, no problem...
    fuzzy1 likes this.
  18. fuzzy1
    10,335
    That fits with our understanding. By putting them in the trunk, they have no legal notice what car you will put them on. It is quite reasonable for them to presume, without asking, that you will put them on your other older non-TPMS car. ;) And you are not under any similar legal constraints on your own car fleet.
    Otherwise, you could just head north to a tire shop in Vancouver. The big one farther away, not the little closer one.
    cyberpriusII likes this.
  19. cyberpriusII
    1,150
    1,682
    Iowa
    Hmmm, bigger is better. :eek::D:eek:
    Actually, he also mentioned something about if I brought in a car with the TPMS system lights all reading A=OK, the car has to leave that way. If somehow, I let air out of the tires in the parking area before they pull it into the bays, there is no legal obligation to fix it, but he sort of lost me on that argument...
  20. bisco
    51,011
    when did tire guys become lawyers?:cool:
