Head gasket Repair. Need shop suggestions?
Discussion in 'Gen 3 Prius Main Forum' started by Danieley4, Apr 22, 2019.
  1. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Most if not all engines have donor vehicle pictures, and gen 4 wont have really old engine compare to gen 3’s. They have 6 month warranty on the block and not the bolton stuff like air intake, water pump,egr assembly
    Ragingfit likes this.
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    But if you've already gone to all the trouble of installing and firing up the replacement engine before you discover there's a major problem...?
  3. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    If this was my car or one of my customers’ cars, I would still recommend going with a new Gen 3 short block from Toyota ($2k) instead of a Gen4 swap. With a new short block it becomes a true “plug and play” repair with no known compatibility issues. To a potential buyer, the new Gen3 short block adds real value (imo) and does not generate concerns about the quality of the repair.
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    The engines are literally identical. The return hose is just angeled different. Third gen comes out straight where 4th gen is 90 degree. But your route would break the bank even more. Some of this cars have more than 300,000 miles and filled with carbon in egr and intake ports.
  5. Mendel Leisk
    40,471
    Looking at the short block, say on McGeorge Toyota, it's confusing. Do you get a complete sub-assembly, everything below the head gasket, or is it just the main casting, and then you've got to buy the pistons rings, crankshaft, oil pan upper, oil pan lower, and on and on?
    Here's the link, if I enter info as a 2015 prius (which seems most prudent, to ensure the updated pistons/rings), and then search for "short block":
    Short Block - Toyota (11400-37140) | Toyota Parts
    And the price is $1724
    Then, here's the link to "engine" category, and item #1 is "short block", and the same price, but it's just pointing at that single casting. For example, item #31, the casting below, is distinct:
    Engine for 2015 Toyota Prius | Toyota Parts
    They're certainly not spelling out, what a "short block" includes. I'd like to think you're right, but that seems like a really good price (hopefully true), when you start added up the component prices.
    Googling a bit more, what a "short block" is, you must be right.
    #25 Mendel Leisk, May 2, 2019
    Ragingfit and The Critic like this.
  6. The Critic
    3,193
    2,327
    CA
    A "short block" includes the crank, bearings, pistons and rings. And it is fully assembled. You simply provide the oil pump, oil pan(s), cylinder head (and everything north of it).
    This diagram provides a better visualization:
    SHORT BLOCK ASSEMBLY. For Prius v | Village Toyota Parts
    Everytime I see an engine that has been retrofitted in a car to make it work, there are usually issues. Whether it was an install issue (due to an incompetent installer) or a true compatibility issue. Those are usually cars that I avoid, and most customers that I've talked to are not crazy about the idea. If you plan to keep the car and you make the minor changes, it is probably fine. But the car will be difficult to resell, at least to an informed consumer.
    Raytheeagle, JC91006 and Mendel Leisk like this.
  7. Mendel Leisk
    40,471
    New oil pans, upper and lower, item 31, would push the price up about $360. But yeah, you can very likely swap over from the old engine, no problem.
    The Critic likes this.
  8. The Critic
    3,193
    2,327
    CA
    Toyota Prius Hybrid 1.8L 2ZRFXE New Short Block Genuine OE OEM 11400-37140 | eBay
    $1979 sounds like a smoking deal to me. Plus it was assembled in Japan. Just add the overhaul gasket kit and machine shop work (for the existing cylinder head) and you should have a very reliable engine for around $2500.
  9. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    The only thing that gives mine away that the Gen 4 block has been retrofitted into mine is the unplugged oil level sensor. The stealership even pointed that out in the inspection when they did my hybrid system update. When I picked it up, I let them know what I did. The technician didn’t even know it was possible. The service writer was blown away.
    RMB, Ragingfit, Threej and 2 others like this.
  10. The Critic
    3,193
    2,327
    CA
    So there is no place for the oil level sensor on the Gen4 engine? We should have a sticky thread on the differences between the two engines. If the car is scanned with Techstream does it show any oem-specific dtc's for the oil level sensor?
    Raytheeagle and spiralhelix like this.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    The sensor is on the Gen 4 block. It’s not on a Gen 3 wiring harness to plug it in.
  12. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    This thread just reminded me, it’s been more then 24 hours since I checked my oil and antifreeze. LoL
  13. Mendel Leisk
    40,471
    Ok, so both gen 3 and 4 have oil pressure sensor, only gen 4 has oil level sensor?
  14. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    Yes that’s correct. The Gen 3 has no provision for monitoring the level.
    kc410, RMB, Ragingfit and 3 others like this.
