Hey! Here’s a thingy!
Discussion in 'Gen 3 Prius Main Forum' started by Bentg, May 15, 2019.
  1. Bentg
    Bentg Member
    36
    49
    New Prague, Minnesota
    FC0F21A2-ACE6-4DDA-9E7E-44125B350202.jpeg New to the Prius. What’s the practical purpose of this thingy? As far as I can tell, it just sorts of...flops around in there. What are you guys using it for?
    51,896
    i didn't get one of those :(
  3. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    It's a little try for anything that will fit there.
  4. bisco
    51,896
  5. Prodigyplace
    12,548
    11,772
    Central Virginia
    I tho k it is supposed to hold coins for tolls if you do not have an EZPass.
  6. ChapmanF
    18,147
    Back when they designed that thingy, phones were small enough (those were the days!) to fit in it. Your charging cable could even sneak out through the little cutout in the front lip, and down to the power outlet in the bottom of the console. Likewise the audio from your headphone jack (those were the days!) to the aux in jack down there. Or USB cable to the sound system's USB jack, also down there.
    Close the top armrest and smash-and-grabbers wouldn't see any of it. (Nor would they ever, ever guess there might be a phone there, of course.)
  7. Tideland Prius
    16,554
    Anything small. Notepad, key fobs (garage for example), pen, iPod etc
  8. hill
    8,800
    Several new cars have these. We're roaming around southern states in a rental nissan SUV, & a Rav4 & both have 'em.
  9. bisco
    51,896
    i heard all the change falls out when you flip it up
    CR94 likes this.
  10. Bentg
    Bentg Member
    36
    49
    So, yeah. It’s clearly to put things in. My problem is A.) it’s so shallow that stuff falls out of it on pretty much any turn, and B.) it’s completely in the way if you want to get at anything below it.
  11. bisco
    51,896
    when they reconfigured the center console in 2012, they took it out, and didn't put in a lift out model like gen 2 had.
    i found a plastic licorice container at trader joes that sits in there perfectly.
  12. ChapmanF
    18,147
    Phones don't fall out as much as coins do; the usb cable fed through the little notch tends to hold them in place.
  13. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I put my iPod Classic there. I routed the USB cord from the bottom up to the tray. Works well.
  14. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    I keep a 6" ruler and a basic calculator in it. Combined, they fit perfectly and do not fall out.
    Thanks to Chap's interesting suggestion, I'll try putting my mobile telephone in it.
  15. DavidA
    2,345
    1,821
    Chicago western burbs
    I couldn't find a good use for the tray. Took mine out on day one as it looked like the rattling would drive me crazy, especially if I had coins sliding around in it, and it was going to be in the way for access to the main compartment. I put the tray back in on the car's last day when I traded it in.
