Refurbished MFD - Should I be concerned?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Abq Richard, Sep 1, 2006.
  1. Abq Richard
    Abq Richard New Member
    59
    Albuquerque, N.M.
    The MFD on my 2006 failed after only 5 months/5000 miles. They want to replace it with a refurbished MFD, not a new one, which I am told is standard procedure. Does anyone have any sense if this is something I should be concerned about? I did not have terrific luck with the longevity of a refurbished CD changer, but don't know if refurbished components are generally less reliable. The MFD is a comparatively troublesome component of the Prius, and I don't want to do anything that makes it more likely that I will experience further problems in the future. Any guidance from those of you who have some experience or knowledge about this would be appreciated.
    Richard
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    haven't heard of any problems with a refurbished MFD yet, so no worries. how did yours fail? what did it do?
  3. Abq Richard
    59
    Albuquerque, N.M.
    <div class='quotetop'>QUOTE(galaxee @ Sep 1 2006, 12:01 PM) [snapback]312856[/snapback]</div>
    Mine just totally died. No flickering or intermittancy like some reported in other threads. The screen was just blank a week ago Thursday when I turned the the car on to drive home after work.
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    At minimum, i'd confirm with them what the warrenty coverage will be on the refurbished MFD...
    refurbished generally means someone sent the part back in because it wasn't working (like your MFD, for example), they took it apart, found the part that was broken, and fixed it... you might think this takes a bunch of added time and effort and they could give you a new one cheaper, but in reality they'd be doing most of it anyways to try to figure out if there's a comon failure point in the item and why.
    So refurbished should mean fully functional, no more problems. I'd guess that with your CD changer it just wasn't that great of a design anywawys, and destined to fail early, regardless of being refurbished or not.
  5. Abq Richard
    59
    Albuquerque, N.M.
    <div class='quotetop'>QUOTE(eagle33199 @ Sep 1 2006, 12:09 PM) [snapback]312861[/snapback]</div>
    I will still have the remainder of my three year warranty on the MFD. I was also told that there is a one year warranty on the part, so if this happened to you near the end of your warranty period or after, you would have some additional protection.
    You're probably right about the CD changer, although it was, in theory, a higher end component.
  6. Tideland Prius
    16,615
    Yeah ask if that 5 months will get added on after the basic warranty expires (IOW, see if you can get the MFD covered for a full 3 years)
  7. Abq Richard
    59
    Albuquerque, N.M.
    I haven't decided what I'm going to do on this yet, although I don't know that it is worth making a fuss over. FWIW, though, the warranty provides: "Any needed parts replacement will be made using new or remanufactured parts." The question then is: who gets to pick? Interestingly, that paragraph goes on to say that the decision as to whether to replace or to repair parts will be made by the dealership or Toyota, but it doesn't address who is to make the decision as to replacement with new or remanufactured parts. Since it didn't reserve that right to itself or the dealership, however, I would think I should at least have some say in that matter. There is an arbitration provision to resolve disputes, to take not more than 40 days.
