hesitation on acceleration even on a new battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, May 26, 2019.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Dears
    I need help here please..
    I put a new hybrid battery on my car and still there is some hesitation when acceleration specially in a traffic crisis,and when the car starts to charge up the battery when its 2 bars..
    So what to check in the car and what to clean or what to do ?
  2. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    Where did you get the battery? is it truly new from the Toyota factory?
    Have you got any diagnostic tools like techstream, dr. prius, torque etc?
  3. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Yes it's new from toyata factory...there was huge hesitation but now less hesitation...but i need to get rid of it
  4. bisco
    51,023
    sounds like an engine problem. if you're at two bars, the battery isn't supplying much power.
    how many miles/km on her? have you cleaned the throttle body? egr circuit?
    #4 bisco, May 26, 2019
    tankyuong likes this.
  5. Tariq87
    Tariq87 Member
    87
    28
    jordan
    180000 km .. and i cleand everything in OCT 2018..
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    I don't think that is true at all.
    The amount of power the battery supplies should not vary enough so so that you can tell the difference.
    I'm not sure that a slight hesitation is not "normal" when "jumping on it" to get sudden acceleration.
    I agree that it might be a gas engine problem.......if there really IS a problem.
    Note: It is generally accepted that ACCELERATING is NOT a good way to get yourself out of trouble in any traffic situation.
    But then things might be different where you live.
  7. Tariq87
    Tariq87 Member
    87
    28
    jordan
    I live in very hot country in summer "jordan"
    When the weather is very hot the car starts to hesitate alot..and also as i mentioned before in huge traffic also
  8. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Is the coolant level for the engine stable?
  9. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Stable since 2010
  10. Mendel Leisk
    40,466
    It seems to me when it's down to two bars it's "slightly" sluggish during acceleration. I'd suspect it's the car's programming, being more protective of what charge is left.
    bisco and Raytheeagle like this.
  11. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Some additional questions:
    • How many miles on your Prius?
    • Egr circuit cleanse complete?
    • Plugs changed?
    • Throttle body and map sensor have been cleaned / inspected?
    • Any dash lights?
    • How’s the fuel pressure / delivery?
    Hesitation is caused by 2 main factors : air or fuel so that’s where I’d focus if the coolant level is stable and the head gasket isn’t compromised.
  12. Tariq87
    Tariq87 Member
    87
    28
    jordan
    1- 180000 km / model 2010
    2- egr cleaned in oct 2018
    3-throttel body cleaned oct 2018 map sensor checked
    4-no dash light
    5-i need to know how to check fuel pressure?
    6-coolant level stable since i bought the car in 2010..
    7-i used octan 95 for it since 2010
  13. sam spade 2
    7,035
    2,798
    2017 Prius c
    Air filter......fuel filter........?
    Vacuum or intake manifold leak ??
    There haven't been any modifications to the intake or exhaust, has there ??
    A healthy dose (or two) of a good fuel system cleaner might help some too.
    (Seafoam is NOT a really good cleaner.)
    BUT you have a fairly old car with a LOT of miles and some small performance loss is probably to be expected.
    How's the oil usage ?
    IF.....something is causing it to run a bit more lean than normal, when it gets really HOT it will get even leaner.
    And finally, is the fuel you are using considered "premium" high octane where you live ?
    If so, try going back to "regular" grade, which is all the Prius ever needs.
    #13 sam spade 2, May 26, 2019
  14. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Air filter changed recently and fuel changed in toyota factory recently. .
    No changes in intake or exhaust...
    But the car consume much oil..
  15. sam spade 2
    7,035
    2,798
    2017 Prius c
    How much ?
    Engine wear also causes loss of performance when it gets bad enough.
    Read my last post again. Some edits have been added.
  16. Tariq87
    Tariq87 Member
    87
    28
    jordan
    I use fuel cleaner each 6 months .
    The car took 4.5 liters with oil filter..so the car consume all the oil after 3 months .
    Yes it's premium fuel..
    I tried the regular fuel but the engine sound changed to rough so i go back to premium fuel and the car gave me better milages
  17. Mendel Leisk
    40,466
    What would that be a symptom of, excessive carbon in combustion chamber?
    More evidence, maybe carbonned up piston rings causing high oil consumption? Can you quantify that oil consumption: how much oil consumed per say 1000 kms?
    Things to try:
    1. Use an inspection camera, see what the combustion chambers look like. Look for carbon, also evidence of coolant, and just a marked difference between the cylinders.
    2. Maybe worthwhile to remove the pistons and pour a couple of ounces of carbon-busting solvent in each cylinder (aforementioned SeaFoam?), let it sit for at least a day, then manually crank the engine a few times, baste out any solvent that remains abouve the pistons, reinstall plugs/coils, drain and replace oil.
    3. Compression test?
    4. Leak-down test?
  18. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    What about the spark plugs?
    Like most cars, a Prius cannot determine its own fuel pressure. To test, you must temporarily install a pressure gauge on the fuel line and then run the pump to take a reading.
    Raytheeagle likes this.
  19. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Thanks for helping me... during this week i will do what you said and i will update you..
    God bless you
  20. bisco
    51,023
    agree with mendel. if it is too hot, car goes into battery protection mode. can you hear the cooling fan running? have you cleaned it?
