Removing instrument cluster trim
Discussion in 'Gen 4 Prius Accessories and Modifications' started by justice37, May 30, 2019.
  1. justice37
    justice37 Junior Member
    Oregon
    2019 Prius Prime
    Hi
    Anybody knows how to remove this plastic trim around instrument cluster?
    There is clip rattling behind this trim.. wanted to tighten it.
    amos likes this.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    Why not have the dealership deal with it?
  3. justice37
    Oregon
    2019 Prius Prime
    They claims that this is normal range of noise. Nothing can be done.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    This won't get you all the way there, but it's a start.
    amos and Mendel Leisk like this.
  5. Mendel Leisk
    41,301
    Might be a case where you have to take the rest of the dash off first then? They seem to enjoy designing it that way .... :cautious:
    amos likes this.
  6. jerrymildred
    11,517
    14,147
    Tampa, FL
    Gen 2 is like that. You have to take all the plastic off to access the combo meter. Not hard, just lots of stuff.
    kithmo likes this.
  7. Mendel Leisk
    41,301
    Yeah I wanted to have a look at our 3rd gens temp/humid sensor. It's right by your right knee. I had to take off the shifter, centre console, various central trim bits. Just nuts.
    I have pics here somewhere, looks half gutted, lol.
  8. amos
    amos Active Member
    365
    282
    los angeles
    Im having thw same problem with my 2016 prius. Mosquito noise. Im thinking of taking all that dash apart. Makes me crazy.if i put a heavy weight on the dash, it stops.
    Any good youtube on yhat matter?
  9. jerrymildred
    11,517
    14,147
    Tampa, FL
    I'l be googling for that when I get time to address my little buzz. Mine sounds like it's right behind the 11.6" display. It's not bad enough to take it to a shop, but it might be worth fidiling with myself when I have some time.
    amos likes this.
  10. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    That video shows the way to take off the lower dash, the upper dash (behind the MFD cluster), isn't too difficult.
    I forget if the A-pillar covers needed to come off first, I think not, but doesn't hurt to look closely to see what is overlapping what. Remove the speaker grilles, they just pop out (but using a plastic pry tool makes it MUCH easier), there may be bolts under the grilles, I can't recall, then pull the entire piece back at an upward angle, paying special attention to the rearmost corners, as they have clips on them.
    amos likes this.
  11. justice37
    Oregon
    2019 Prius Prime
  12. jerrymildred
    11,517
    14,147
    Tampa, FL
    I didn't have time to read the whole thread, but it looks like that is a TSB just for the 2016, and not for Prime. Also, it addresses a buzz from the left, not the center, as I'm experiencing and as per the original post.
    That said, there could be a very similar cause to both of these noises.
