I've searched the forums to no avail, my 2013 Prius 2 is misfiring in all cylinders after replacing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allison Meggison, Jun 10, 2019.
  1. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    I recently replaced all the coils and plugs in my prius because there was a misfire in cylinder 2. She still continued to rattle after replacing all these things so I had a mechanic replace the fuel injector in cylinder 2, the problem continued. Now it pops codes for a random/multiple misfire, a misfire in cylinder 2,3, &4. I had the 12v battery replaced also because the previous owner had installed the wrong battery with the wrong terminals and the first mechanic thought the rattle was being caused by the lack of power. What should I do? It rattles almost every time i start her up and most of the time when I'm accelerating after a stop. Sounds like when you run over a rumble strip on the highway.
  2. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Patience. The experts will be checking in soon.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Egr circuit cleaned?
  4. ChapmanF
    18,056
    Compression test?
    Raytheeagle likes this.
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Cleaned intake manifold?
  6. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    Mileage?
  7. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    1. Misfires suddenly spreads to other cylinders, tells me the some of the new coils or spark plugs you got might have issues.
    2. When you removed the #2 spark plug, was it soaked with engine oil? If yes, then the valve cover gasket is weak and needs replacing.
    In dome cases, if the piston oil/compression rings are weak, oil can foil the plugs.
    Do a compression test, as suggested by @ChapmanF .
    3. The connectors on the fuel injector and the ignition coils on #2 should be properly inserted.
    An improperly fixed conne for would cause such problems too.
    4. If after doing #4 and no improvement, you got to be preparing to replaced the ECU (injector driver is embedded in it).
    5. A damaged top cylinder gasket would be the next thing after all the tests above.
    Pluggo likes this.
  8. DThrill
    DThrill Junior Member
    Phoenix, AZ
    My misfire was computer misdiagnosed as first as bad engine coils and overdue spark plugs.
    What it was: Leaking Top cylinder head gasket..didn't know until radiator fluid dumped into cylinder 1 and Engine overheated.
    Had to get heads 1 & 2 redone.
  9. Allison Meggison
    71
    El cajon
    Thank you for all the feedback ! I haven’t cleaned the egr circuit or the intake manifold. Maybe I should start there. She has about 228k and has been going through coolant like crazy. Tonight I cleared the codes and later it popped “check hybrid system stop vehicle in a safe place “
  10. Allison Meggison
    71
    El cajon
    Yes there was oil
  11. bisco
    51,835
    allison?
  12. Mendel Leisk
    41,295
    If it's going through a lot of coolant I would focus on the head gasket. It's sandwiched between the engine block and head, and basically makes sure that all the gasses and liquids that need to cross that divide go where they're supposed to. Once it fails, very common is for coolant to start getting into combustion chamber.
    It is good to clean the EGR circuit and intake manifold, but with the miles you're at and the symptoms, I would leave that till after: diagnose the head gasket first.
    Mechanics can do a leak-down test to diagnose failed head gasket. There's another test that involves putting a tube with some solution into the radiator neck, and if it changes colour that'll indicate exhaust gas in the coolant. Now with the Prius not having a radiator opening, not sure if it's doable. I suspect you could do the test with the tube atop the engine coolant reservoir opening, but not sure. Maybe someone else can comment.
    A video on head gasket replacement. These guys don't have the best "table manners", and are cutting a lot of corners, but interesting video:
    Video on the exhaust in coolant test:
    Boffin likes this.
  13. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    There's your sign=blown head gasket=$$$$
  14. Mendel Leisk
    41,295
    Another trick is to run an inspection camera in through the spark plug holes; good chance they'll find coolant.
    Raytheeagle and RMB like this.
  15. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Maybe a boroscope would do.
    RMB likes this.
  16. Mendel Leisk
    41,295
    I wanted to stick with non-esoteric words, but yeah borescope is the mechanical terminology. Basically a camera on the end of a tube, with a integrated light source.
    Montgomery, CR94 and Dxta like this.
  17. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    MENDEL!!!!:ROFLMAO:
  18. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    They’re also known as endoscopes;).
    Just did 2 separate Gen3’s last weekend:).
    Definitely a great tool for the DIY tool box(y).
    CR94 and Mendel Leisk like this.
  19. Allison Meggison
    71
    El cajon
    Thank you for the advice! So I should get a boroscope? Sometimes it sounds like a lot of liquid is being flushed around under the hood when I am stopped, almost like a toilet flushing.
  20. Allison Meggison
    71
    El cajon
    yea?
