I Have a Drinking Problem
Discussion in 'Gen 3 Prius Main Forum' started by Borninblue, Jun 21, 2019.
  1. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    All was well for past 10,000 miles. I have been checking oil about once a month and after 3,000 miles looks like she drank about a 1/4 on me. About 127,000 miles on her so I expected the thirst sooner or later.
    No big deal to me, I bought a couple quarts to have on hand. Still averaging around 49/50 mixed driving. I’m contemplating thicker oil just not sure at this point. Going to monitor to see how thirsty she is for next 5,000.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    A pint in 3000 miles is NOTHING.
    I've had brand new engines that did worse than that.
    If anything, I suggest a very modest increase in viscosity at this point.
    WAY too early to be thinking about a "high mileage" variety.
    When you get up to using a whole quart between changes.......then maybe.
  3. mikes951
    mikes951 Junior Member
    46
    US
    change it to synthetic oil Mobil 1
  4. Mendel Leisk
    40,472
    Not sure what "1/4 in 3000 miles" means. 1/4 of the total oil volume, a quart, or?
    Guessing you meant a quart, that's getting up there, not runaway territory. Try a seafoam soak?
  5. Borninblue
    233
    158
    Cleveland, Ohio
    I meant to say 1/4 down on the dip stick.
  6. Burna J
    1,066
    3,335
    53
    Long Beach, CA.
    I hear there's meeting for that.... Cheers !! :)
    hill, Merkey and Borninblue like this.
  7. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Is that 1/4 of the way from the full mark to the low mark? Or down to 1/4 of the distance between the two above the low mark? Or 1/4 of the way from the full mark to the bottom of the dipstick?
    If it went down 1/4 of the distance of between full and empty, that's about 1 cup of oil lost in 3,000 miles. That is not very high consumption for any engine with > 100K miles on it.
  8. Borninblue
    233
    158
    Cleveland, Ohio
    1/4 of a way down from the full mark. I understand not that much, she was holding steady without ANY loss.m before this. Maybe the start of something or just a little burning we will see.
  9. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    You caught it early. Just throw in a bottle of fuel system cleaner, clean your EGR system and PCV valve. Probably good as new.
    Pixel XL ?
    Raytheeagle likes this.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You are obviously staying on top of your oil level, which is a big plus. Some drivers don't ever check oil level and get the big surprise with either the low oil pressure light or the engine seizing. Time for a spreadsheet, with charts and projections.... :)
  11. frodoz737
    frodoz737 Top Wrench
    4,506
    2,426
    33
    Time to start checking the oil weekly or at fill-up...which ever comes first.
  12. Mendel Leisk
    40,472
    The two marks on the dipstick represent 1.5 liters, or 1.6 quarts. They also happen to be roughly 1.5 inches apart, which works well with liters, pretty much the same with quarts.
    Did a quick ratio equation: if the oil's 1/4 of the way down from the top mark to the bottom, that represents 3/8 of a liter (or quart). 3/8 of a quart is 12 oz's.
    mikey_t likes this.
  13. orenji
    orenji Senior Member
    5,886
    3,487
    Move up to thicker oil. Stay with 0w-30 or 0W-40.
  14. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    No, 1.6qt/4=0.4qt, if the dipstick is linear. It very likely is not, so probably that is at least half a quart.
  15. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Got it. I neglected to check the manual and assumed (that's the problem right there) that the difference between full and low is 1 quart. The manual confirms that the difference is 1.6 quarts.
    Which seems odd, given that oil is normally sold in quart or liter units.
    CR94 and Mendel Leisk like this.
  16. hill
    8,621
