Mechanic Couldn't Figure Out Problem
Discussion in 'Gen 3 Prius Main Forum' started by Karen8860, Jun 19, 2019.
  1. Karen8860
    Karen8860 Junior Member
    Sorry that I'm not very knowledgeable but that's why I am here. I went to my mechanic today and he couldn't fix my fan that randomly turns off and on. The fan that blows ac or heat into the car is called the blower fan, is that correct?. He hooked my car up to the computer and he manually looked at it and couldn't find a problem. When I would pick up speed it would turn up and go faster-sometimes! At other times it wouldn't work at all. I kept it all the way on and up and didn't touch it for three weeks and it worked fine. Any thoughts? And thank you in advance!
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,027
    517
    Tucson, AZ
    2021 Prius
    I'm probably not going to be much help, but I have some ideas. Is your mechanic using the Toyota Techstream diagnostics? If not, then some of the Prius-specific fault codes won't be shown. I would suppose that a decent mechanic would have checked most of the easy things like the 12V battery status. It doesn't sound like a weak battery anyway. There is technology behind the operation of the HVAC system in these vehicles. Specifically something called "fuzzy logic" that controls the fan speed for a given outside air temperature and requested inside temperature. Could be a bad sensor for either of these parameters. A random fan might also be a mechanical problem with the fan motor, although this shouldn't be affecting a 2014 yet. It could even be something goofed up in the ventilation doors that direct airflow to the various vents, windshield, dashboard, and floor, while the fan continues to operate normally. Might be a visit to a Toyota service department in your future.
  3. Karen8860
  4. bisco
    51,023
    try avi at hybrid fix
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    The way the blower motor works on the Prius is through a pulsed signal from the controls on the dash. The faster the pulse, the faster the fan speed. This all takes place from the blower resistor module (which I suspect is where you problem exists) to the fan motor. It’s very simple to check. Three wires: Black power, white ground, blue is pulse signal.
    Pluggo and bisco like this.
  6. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    IMG_6226.JPG I noticed the same thing last week in my new Prius 4 (2018). On one occasion the fan turned off completely. When I tried to figure out what had caused this, I noticed that my temperature setting was set too high which had caused the ac to turn off. As it turned out, a usb cable that I had connected to my smart phone was intermittently hitting the temperature control button next to the 11 inch display. Whenever I used my smartphone (mounted on the adjacent vent) the usb cable would hit the button and randomly change my temperature setting. I found that it doesn't take much to trigger the buttons in the vicinity of 11 inch display. Perhaps you are experiencing something similar to this when you operate your display. To verify this, record the ac temperature setting, then the next time you notice a dramatic change in the fan operation, check the temperature setting again to see if it has changed.
    #6 ice9, Jun 19, 2019
    Karen8860 likes this.
  7. Karen8860
    Thank you so much. I should have mentioned that he is a fantastic general mechanic not a Toyota mechanic as my car is not under warranty or Toyota Care anymore, so he may have not had the current diagnostic tool you mentioned.
  8. Karen8860
    Thanks. Is that a shop or on here?
  9. bisco
    51,023
    it's in LA, avi is a well respected member here. want me to google the address and phone?
  10. Karen8860
    Thank you, no I can do it.
    Raytheeagle and bisco like this.
  11. bisco
    51,023
    please keep us posted!
    Johnny Cakes likes this.
  12. tvpierce
    tvpierce Senior Member
    951
    880
    Maine
    2013 Prius v wagon
    I don't mean for this to be insulting, just trying to eliminate the simple stuff: Is your climate control set to Auto? If so, that would modulate the fan speed based on temperature.
