Lane Departure Warning Not Available
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by eppley1, Jun 26, 2019.
  1. eppley1
    eppley1 New Member
    Pennsylvania
    Four Touring
    For the past few days (I'm not sure how long) my Lane Departure Warning has not been working. When I went into the settings, I saw that, not only was it turned off, but the menu choices were grayed out. In other words, I don't even have the option to turn it back on. What could cause this?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,588
    near Brisbane, Australia
    I assume your steering column switch is <ON>. Have you checked the Owner's Manual - there is an operational section as well as a settings section.
    Are there any warnings or advices on the dashboard?
  3. eppley1
    eppley1 New Member
    Pennsylvania
    Four Touring
    Doh! I was so intent on going through the menus that I forgot there was a button in the steering wheel! That was the problem--I must have accidentally pressed that button which turned it off.
    Thanks!
    Dael likes this.
  4. alanclarkeau
    7,045
    7,588
    Solved!! - good news.
