Prius about to hit 200k, what maintenance things should I look for?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HeinzCatSoup, Jul 25, 2019.
  1. HeinzCatSoup
    HeinzCatSoup Junior Member
    Southern California
    Besides the standard oil changes...what maintenance things should I look to take care of?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,517
    Bay Area, California
    2019 Prius Prime
    Cleaned the egr circuit yet?
  3. Mendel Leisk
    41,000
    And the intake manifold...
    1. Have you ever changed the transaxle fluid? Toyota says it's lifetime, but...
    2. Have you ever changed the brake fluid? Toyota USA says nothing, but Toyota Canada says tri-yearly or 48K kms.
    3. Have you done an occasional brake inspection? Not just the "visual" inspection, the full 30K (or tri-yearly) Toyota USA spec'd inspection.
    Assume the plugs and coolant are already changed, per the schedule?
    #3 Mendel Leisk, Jul 25, 2019
    Magic Mark and Raytheeagle like this.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    All fluids, plugs and EGR.
    Mendel Leisk and Raytheeagle like this.
  5. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    Also...
    Check the brake pads
    Lubricate the brake caliper sliding pins
    Check the Hybrid fan and clean if needed
  6. The Critic
    3,193
    2,330
    CA
    I would be more concerned about the abutment clips than the pins themselves. Rust tends to grow between the pads and the clips, and between the clips and the bracket. This leads to the pads “seizing” in place. The pins are rarely a problem.
  7. HeinzCatSoup
    Southern California
    thank you everyone for the quick replies. Going tostop by toyota today to order some transaxle oil, and i'll probably take apart the brakes and see whats up with them, lubricate the sliding pins, check the clips. then i'll work my way from there.
    spark plugs and coolant have both been replaced
    Rebound likes this.
  8. HeinzCatSoup
    Southern California
    no I haven't done this. Is there a reason for this?
  9. The Critic
    3,193
    2,330
    CA
    The EGR circuit (valve, cooler, manifold) tends to clog up on these cars. According to some people, cleaning this mess will reduce combustion temperatures and this will make your engine head gasket last longer.
    Raytheeagle, Mendel Leisk and CR94 like this.
  10. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    How about water pump change? 3 Gen Prius tend to water pump fail.
    Raytheeagle and The Critic like this.
  11. The Critic
    3,193
    2,330
    CA
    That too
    Raytheeagle likes this.
  12. Rebound
    3,995
    2,643
    Portland, OR
    Both coolants? There are two separate coolant circuits.
  13. Mendel Leisk
    41,000
    When you buy your car, brand new, the intake manifold, and the EGR circuit, are clean and shiney, with unrestricted air flow. After 200,000 miles they are almost without doubt going to look like the bottom of an old barbecue, royally clogged with a carbon/tar mix.
    When I see it, all I can think is "well that can't be good".
    Have a look at this recent post:
    Free weekend for maintenance on 2010 and 2012 priuses (prii?) | PriusChat
    And the next one as well.
  14. HeinzCatSoup
    Southern California
    is this something that should be changed prematurely? my friend's prius just had its water pump replaced after failure. Couldn't I just wait till failure point?
  15. HeinzCatSoup
    Southern California
    holy crap. thank you for that link. i'll get to work on it right away
  16. The Critic
    3,193
    2,330
    CA
    The pumps can sometimes fail intermittently without setting faults. Some believe this contributes to the head gasket problem.
    mjoo and Raytheeagle like this.
  17. HeinzCatSoup
    Southern California
    cleaning the EGR to prevent the blown head gasket seems straight forward enough, but spending $200+ on a new water pump... hmm do i wanna do this as a preventative..
  18. Raytheeagle
    11,265
    15,517
    2019 Prius Prime
    Running things to failure is something I avoided in our 2010, so I did replace the pump before it failed;).
    I also replaced the fuel pump and inverter water pump before each of them told me to.
    When things are run to failure, the state the car is in cannot be controlled. So if you’re going down the freeway when it happens, not so good things happen :cool:.
    I prefer to control these types of things:).
