Why is the Prius's 2 motor generators more reliable than an alternator?
Discussion in 'Gen 3 Prius Technical Discussion' started by Haschwalt, Aug 1, 2019.
  1. Haschwalt
    Haschwalt Member
    110
    35
    New York
    I've read that the reason why the Prius is more reliable than nonhybrid Toyotas is because of the lack of alternator and use of two motor generators. Why is this system more reliable? Less wear and tear on the engine? If so how?
    "Further clarification: The Prius HSD has two motor-generators, call MG1 and MG2. MG1 is smallish and used to spin the ICE and to transfer power from the ICE to MG2. MG2 is larger and is used as a prime mover and for regenerative braking. Both MG1 and MG2 are sometimes used as electric motors, and sometimes as generators. The electricity generated from MG1 and MG2 is either used to move the car or charge the HV (traction) battery. The small 12V battery, which is like the battery on a "normal" car, is charged from the HV battery by means of a DC to DC converter, which steps down the high voltage to that of the 12V battery. The DC to DC converter also supplies the 12V accessory needs when the Prius is in run mode (lights, radio, MFD, etc.)."
    51,604
    that doesn't sound right to me. alternators are pretty reliable. but the motor generators are the heart of the hybrid system, and have to be hyper reliable, because replacing them is no mean feat, and vastly more expensive than an alternator.
    otoh, it would not surprise me if toyota is continually decontenting the ecvt, now that they know it was originally over engineered, and they can save some money going forward.
    they just need to get most of them past warranty
    Haschwalt likes this.
  3. CR94
    CR94 Senior Member
    2,678
    1,160
    Northwestern S.C.
    Alternators have brushes that wear out, are more exposed to contaminants, and are relatively cheaply constructed.
    Haschwalt and fuzzy1 like this.
  4. fuzzy1
    10,344
    Because it must be, as it is part of the core propulsion system. Considering its cost and difficulty to replace, ordinary alternator failure rates would turn this hybrid into a marketing disaster.
    Thus, it is better engineered and protected from the outside environment.
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Back when you had an alternator, it was hung off a bracket and had some pulley pulling on it from the end.
    If you watch the WeberAuto videos, you see very well supported M/Gs with precision bearings. So the stresses are less and motors last longer.
    He does not mention all the bearings, but the video shows them. He mentions a couple of ball bearings, I saw what I think of as Timken bearings.
    In contrast, many alternators are on a long (flimsy?) arm and rotate a pulley at one end, pretty much unsupported.
    (this alternator is painted red, perhaps by the same individuals trying to sell red solenoids)
    #5 JimboPalmer, Aug 1, 2019
  6. ChapmanF
    17,832
    And are not liquid cooled.
