New hybrid issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sharnold, Aug 5, 2019.
  1. Sharnold
    Sharnold Active Member
    400
    126
    Alabama
    I'm getting P0A4B P0B42 I'm going to have to remove the battery tomorrow and check the harness and module for corrosion these are the only codes pulling
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Raytheeagle likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    You sure do get all the fun ones....
  4. Sharnold
    400
    126
    Alabama
    You know I do lol I'm fixing to inspect and will fill in later
  5. Sharnold
    400
    126
    Alabama
    Just pulled the battery cover checked all cells and harness has very little corrosion but functioning...... now the fact of the matter it's the inverter ecu and luckily I have another
  6. Sharnold
    400
    126
    Alabama
    Cleared one code changing the inverter still getting P0B42 any ideas other than the harness being corroded battery packs all showing 8.5volts
  7. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Did the P0B42 have freeze frame data? Isn't it similar to "Block 2 becomes weak"?
  8. Sharnold
    400
    126
    Alabama
    It is block 2 low voltage p0b42 block b weak voltage but I'm debating that the harness itself is faulty due to the cells being the same voltage as the rest any other ideas I'm always up for the help
    #8 Sharnold, Aug 6, 2019
  9. Sharnold
    400
    126
    Alabama
  10. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Are you using techstream? Do these codes supply freeze frame data?
  11. Sharnold
    400
    126
    Alabama
    I currently do not have tech stream but have been reading on how to buy one and set it up. This car was of course scanned at a dealer and brought to me bc all they wanted to do was throw a new battery and inverter ecu at it I am the only one in my area who will touch a Prius and have rebuilt many battery packs with success this one is just being a pain I have another HV ecu and wiring harness I'm just debating on changing them or just replacing block 2
  12. Mendel Leisk
    41,474
    Raytheeagle and Skibob like this.
  13. Sharnold
    400
    126
    Alabama
    Lol right that would be sacrilege on two counts
    Skibob and Mendel Leisk like this.
  14. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Yuengling! I love Yuengling. Whenever im back east I drive to Pennsylvania and buy Yuengling lager from a beverage distributor. I miss Stoney’s too but you gotta go to Pittsburgh for that. And you really need a copy of techstream and at least a mini VCI. You can find older free copies of Techstream online pretty easy and attempt to install it even before you get a mini vci.
    Google techstream 12.20.018 and see what pops up.
    #14 Skibob, Aug 7, 2019
    Raytheeagle and Sharnold like this.
  15. Sharnold
    400
    126
    Alabama
    I appreciate it sir thanks for the tip I'm a big yuengling fan it's my Prius headache cure
    Skibob likes this.
  16. Sharnold
    400
    126
    Alabama
    Still getting P0B42 after replacing block B cells also the dash display currently shows the HV battery is not charging and yes I checked with the cover off manually. I'm stumped any ideas guys all the cells are the exact voltage charged and discharged this is a tough one you can crank and drive the car perfectly no issue other than not charging the HV battery. I'm thinking HV battery computer failure ......also every dash light imaginable is on. I'm about to replace the whole hv battery cut my loses and move on I got 5 atm and this one is costing more time than I'll get in labor. Also on a lighter note the majority of Prius I work on are rebuilt titles
    #16 Sharnold, Aug 8, 2019
  17. Sharnold
    400
    126
    Alabama
    Robbed Peter to pay Paul for $60 just an hour drive and gas 20190811_085301.jpeg 20190811_090123.jpeg 20190811_090237.jpeg
  18. Sharnold
    400
    126
    Alabama
    Problem solved it was the smart box and fan easy fix she's getting picked back up this evening
    Skibob likes this.
  19. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    The battery in the picture just below this line is a replacement from Toyota. The giveaway is the extra stickers on the case. I could not make out the date codes on the modules from the picture with the beer. Hope you left all of those newer modules in place.
    SFO, Skibob and Raytheeagle like this.
  20. Szulkarn
    Szulkarn Junior Member
    Indonesia
    Sorry to bring up an old thread.
    I am having a P0B42 code.
    Slight corrosion in the terminals and got it cleaned up. Toyota tech reassembled and the code still persist.
    If the smart unit is broken, would techstream be able to pick up the voltage readings of each block? Like the picture i uploaded. Thanks
    Could u elaborate how the fan and the smart unit is broken?
