De-badging help
Discussion in 'Prime Main Forum (2017-2022)' started by jb in NE, Aug 8, 2019.
  1. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Has anybody fully debadged a Prime? I took off the rear badges (except for the Toyota emblem) and am considering removing the front fender emblems that say "Plug in Hybrid".
    I know on the Gen 2 that the badges in this location cover a hole in the fender. Does anybody know if there is a fender hole under the Prime badges in this location? There does not appear to be one in this explodo diagram, but these aren't always accurate.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I recently did this...
    I am typing now.
    Rob43
  3. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Ummm… why?
  4. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Cut through fender emblems with dental floss, this will take 1 to 2 minutes per emblem & several feet of floss because of floss breakage.
    I've tried multiple orange/citrus cleaners, Zep heavy duty from Home Depot seems to work the best. Next get yourself 2 small clean cotton rags (old socks) & soak one with Zep. Basically you go back n forth between the wet Zep rag & the dry cotton rag, each side might take as long as 30 minutes of elbow grease to finish.
    Rob43
  5. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Because I like the look of the car without the badges.
    I know how to remove the badges. What I don’t know is if the fender badges cover any holes. I would prefer the badge to an exposed hole in the fender.
    #5 jb in NE, Aug 8, 2019
    Fostel likes this.
  6. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    More aerodynamic... less weight... it's a win-win.
    :D
    I suspect it's mainly for a clean look though
  7. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    No holes...
    Rob43
    jb in NE likes this.
  8. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Thanks. I missed that in my search. Pretty lame searching on my part.
  10. Mendel Leisk
    40,247
    If you're using the PriusChat search, I find a lot of times, the first search shows nothing (even if the search string is a letter-perfect version of the thread title), but repeating the search, it finds stuff, not necessarily in optimum order.
    In short, it's pretty useless, lol. Often better results can be had using Google search, with search string prefaced with "PriusChat".
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Thanks. Good tip.
  12. Fostel
    Fostel Member
    96
    29
    Kent
    Excel
    Why not use one piece of thin fishing line with no breakage?
  13. Trollbait
    12,242
    Not everyone fishes.:)
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
  15. Mendel Leisk
    40,247
    Oh c'mon, an angle grinder'll do. :ROFLMAO:
    noonm likes this.
  16. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Why half measures? Strip the paint, reveal the beauty of metal work (plus weight savings).
