Engine failed to start, replaced MAF, now says Fuel Run Out
Discussion in 'Gen 2 Prius Main Forum' started by montiebroo, Aug 16, 2019.
  1. montiebroo
    montiebroo New Member
    Asheville NC
    So i am getting the 533 code. The workup says to look for trouble codes and go down that route. So should i now try to fix the “fuel run out” trouble code?
  2. montiebroo
    Asheville NC
    I found the p0A0f code is 533.
    Also.... i just disconected the 12v for 45 ish minutes and now the gas gauge also says empty
  3. JC91006
    JC91006 Senior Member
    16,746
    8,552
    If there is actually fuel in the car, it can take up to a day to detect it
    Raytheeagle likes this.
  4. montiebroo
    Asheville NC
    Welp.......
    It was just.....
    Out of gas....
    I put 3-4 gallons in it and it started right up. I hadnt tried before because the gauge said i had more than a half a tank and i had only gone 150 miles since last fill up according to the trip display. But my combo meter is on the fritz so maybe that caused it? Either way, yay i can drive it again.
    Thanks for all the help even though it turned out to be something simple.
    SFO, Mendel Leisk and Skibob like this.
  5. Marty2go
    Marty2go Junior Member
    39
    Ohio
    Four Touring
    I'm Only replying because the search engine is not picking up the workup for these P codes. P3190 P3191 P3193
  6. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Sometimes the great firewall of China gets in the way, or it could be a server issue somewhere. Hard to say.
    EDIT : Just tried the above link(s), and this time I had to add an exception (not a permanent one) for an unsecure link/server, which is something I've never had to do before. Could be that a server needs an updated certificate.
    I've never used the following link, but it should contain everything you need : Service Manuals - Google Drive
    Would be great if someone could extract the manuals from the Gdrive and back them up on http://mega.nz/ as well.
    #26 SFO, Jan 10, 2021
  7. futbol9
    futbol9 Junior Member
    Hello I have a 2009 touring prius that I took to toyota for oil change. When I got car back engine light was on. They took it back in to reset it but when they came out the hybrid battery light was on. Technician told me I could drive it like that but the hybrid battery was not going to work. They took it back inside and they replace mass air flow sensor but this time car would not start. They said sensor was good. However, They said there was a problem with the harness where mass flow sensor its connected cause everything they would mess with harness it will pull up different codes and mess up the car?? Car was not starting at some point so they reseted car again and car it's been runnimg smooth like always. Guy said its probably electrical problem.
  8. JC91006
    16,746
    8,552
    How much did they charge you for all this guess work? You might have a weak/failing 12v battery, did they check that?
