P0A80 upon hitting bumps in road
Discussion in 'Gen 2 Prius Technical Discussion' started by Sharnold, Aug 24, 2019.
  1. Sharnold
    Sharnold Active Member
    394
    123
    Alabama
    I recieved a gen 2 Prius in the shop with the dreaded triangle and P0A80 after removing the HV battery and checking all the cells and block voltages all where matching charged and discharged I decided to throw the battery back in the car after driving 20min with no code I returned to the shop on the way I hit a pothole and it reset the same code. Upon further inspection none related to the HV battery I found that the drivers wheel bearing was wore slap out and the vibration of hitting a bump or a sharp hard turn set the code due to the CV transmission recieving a good jolt due to the axle vibration also pulled code P0A7A generator inverter fail ......... new wheel bearing problem solved.......... this was just a write up to help others who may be experiencing some of the out of ordinary while working on the gen2
    #1 Sharnold, Aug 24, 2019
    bisco and audiodave like this.
    51,024
    thanks!
    that's a first, afaik
  3. Skibob
    Skibob Senior Member
    2,912
    1,501
    Northern California
    You must fix a lot of battery’s
    Raytheeagle likes this.
  4. Sharnold
    394
    123
    Alabama
    Mostly I work on the stuff the dealer only wants to put a new battery in or cars bought at auction good and or totaled and rebuilt title I have 3 at the garage now
  5. Skibob
    2,912
    1,501
    Northern California
    So I’m gonna guess that’s yes then? You sound like a Prius champion, the little guy that helps out the regular people that can’t afford the dealers high priced repairs. Kudos to you sir. I hope you have most success helping Prius owners in need. (y)
