Can I use a 240v Leaf EVSE to charge my Prius Prime?
Discussion in 'Prime Plug-in Charging' started by a1lawng, Sep 6, 2019.
  1. a1lawng
    a1lawng Junior Member
    17
    Boston, MA
    2018 Prius Prime
    Hey Everyone,
    My wife recently upgraded to a 2018 Prius Prime (loves it!) after her 2009 Prius was totaled. I drive a 2019 Nissan Leaf and we're wondering if we can use my 240v Leaf EVSE to charge the Prius at 240v.
    Are all/most J1772 EVSEs interchangeable or is it possible that the Leaf EVSE contains Nissan-specific circuitry in the brick that might make using it on other EVs a bad idea? It would be great to know if anyone's tried this.
    Thanks for any advice you can give.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,516
    Bay Area, California
    2019 Prius Prime
    They’re J1772, so you’re good(y).
    DickyDck likes this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Yes
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,145
    Tampa, FL
    Yup. J1772 is J1772. It's an industry standard. Quite a few people use Leaf EVSEs for their Primes or PiPs.
    Raytheeagle likes this.
  5. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    I use a Ford Cord that is J1772 to charge our Prime at work;).
    Cheap find on Craigslist that works well(y).
    Prius from Dad and jerrymildred like this.
  6. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I bought my used Plug-in Prius from a Nissan dealer and was told there was no EVSE with the Prius. After sealing the deal I asked if they didn't have a used one from a Leaf laying around. He went in the shop, got one, and threw in the back for me. Works fine.
    noonm, jerrymildred and Raytheeagle like this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Like everyone said, yes it will work flawlessly.
    You can also use your 120v OE Toyota EVSE unit at 240 volts, this also works flawlessly and your charge up time will be 2 1/2 hours.
    If you have a NEMA 6-50R, 10-50R, or 14-50R as your EV receptacle, splitting that 50 amp power source Without an electrician is simple and cheap. Then your 240v* Nissan EVSE can charge the Leaf at the same exact time that your OE Toyota EVSE charges your Prime at 240v for 2 1/2 hour fast charging.
    Rob43
    * This assumes your 240v Leaf EVSE operates at 16 amps.
    #7 Rob43, Sep 6, 2019
  8. jerrymildred
    11,517
    14,145
    Tampa, FL
    Just to clarify for anyone who might not know — that dealer was wrong unless he just meant that that particular PiP didn't have one. If you're buying a used PiP (or Prime) and it doesn't have and EVSE, I think I would expect a price adjustment for buying the missing equipment.
    noonm likes this.
  9. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    You might want to check and see if it was one that's part of a recall.
    Ford Issues Two Safety Recalls in North America | Ford Media Center
    Sorry but I don't know how one would check the cord specifically. I'm still using mine FWIW.
  10. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    I use this cord on the 8 amp setting and a GFCI :).
    Definitely no extension cord;).
    The seller of the cord works at te dealer, so I’ll check and see if I can get a new one. Never know unless you ask(y).
  11. fotomoto
    5,632
    3,805
    So. Texas
    Mine is connected to a timer box so I really don't think the new one with the thermistor would help anyways.
  12. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    Just sent my seller a reply, so we’ll see what he says:).
    But my setup is similar and I am not concerned ;).
    Thanks for the link and awareness(y).
  13. a1lawng
    17
    Boston, MA
    2018 Prius Prime
    Awesome. Thanks everyone!
  14. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    Just an FYI... the charger is actually in the vehicle. The cord simply provides power.
    The cable is like a water hose, the charger is the valve, and the battery is the tank
  15. a1lawng
    17
    Boston, MA
    2018 Prius Prime
    Understood. I just wasn't sure if there was something in the Nissan brick that might cause it to be incompatible with the Prius charger. Thanks for the help.
  16. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    Just got back from my original sellers house with something new:):
    He even let me keep the original purchase:
    Never hurts to ask(y).
