What Did You Do To Your Gen II Today?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by romad, Oct 26, 2014.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Is that a Gen3 from the rear:whistle:?
    I bet you’re tainted by the pip in this regard;).
    But it turned out nice(y).
    jerrymildred likes this.
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I guess great minds (or feeble ones) think alike. I'm picking up the paint this afternoon to touch up my spoiler in a day or two as the weather dries out. I'm going to stick with the Barcelona red, though. Did you take the spoiler off the car and do the whole thing or leave it on the car and just paint the top? A shot of clear coat over the paint?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Sure looks like my PiP, doesn't it? And yes, I do like the black accent. Makes me want to do something about the garage door wounds in my PiP's spoiler. It has actual gouges.
    Raytheeagle likes this.
  4. jerrymildred
    11,517
    14,158
    Tampa, FL
    I took it off. It's no harder than masking it and maybe actually easier. There are four bolts to remove from under the middle section of inside black trim. (Remove the bottom one first and then the middle one that's in line with the wiper arm cross section. I read somewhere that you need to remove the wiper motor and arm, but there was no reason that I could see to take it off. Once the spoiler is unbolted and the center brake light is unplugged, use a plastic pry bar tool to pop up the two ends from their clips. Those are odd looking clips. The spoiler has square plastic holes that snap over white round buttons in the hatch. Then there's a regular clip in the center like the ones that retain the plastic panels you removed from inside the hatch. Two screws to remove the tail light and thread the pigtail through the holes and you're all set.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Well, 63deg (F) in Nashua today, so I took ChuggyPig to the car-wash (a good opportunity to try one of those car washes where the brushes dance around and over the car instead of dragging the car, kicking and screaming through the wash) - it seemed to work very well, no damage, and got rid of all the narsty salt! Then I waxed all the glass (see Chris Fix's method of cleaning the windshield (youtube). :) ChuggyPig.jpg
    srellim234, gta_ and Raytheeagle like this.
  6. ParadisePrius
    ParadisePrius Junior Member
    Fiji
    WilDavis likes this.
  7. ParadisePrius
    Fiji
  8. DanGiant
    DanGiant Junior Member
    Bremerton
    donbright, srellim234 and SFO like this.
  9. BLNT
    BLNT Junior Member
    37
    Hungary
    Placed rubber underneath the edge of the centre speaker's edge to stop it's rattling. This is a 05 with JBL sound system. I cut out the rubber part from a rear rubber trunk guard ordered from AliExpress that did not line up perfectly, so I decided to use it for something else.
    This was the rubber guard:
    BROSHOO Car Styling Rubber Rear Guard Bumper Trunk Protector Trim Cover Strip For Toyota Yaris RAV4 Camry Avensis Verso Prius IQ-in Styling Mouldings from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
    donbright likes this.
  10. Davidude
    Davidude Junior Member
    94
    Georgia
    Looks clean. My solution (and everyone else's I've seen) has been to shove 1-2 pennies underneath and it fixes the rattling. Yours looks a lot cleaner.
  11. rodri9o
    rodri9o Junior Member
    56
    22
    NY
    Today:
    -Finished changing bulbs to LED: did license plate lights and driver/passenger door lights.
    -Quick waxing.
    -Sorted out the licence plate bracket in the rear. Gen II Prii don't have rear plate brackets, but mine came with one. The plate mounting screws were stripped so I went and got another one at a local auto parts store and installed.
    Over the last week:
    -Replaced passenger side headlight bulb. (waiting for driver side)
    -Replaced plugs
    -Replaced air filter.
    -Oil and filter change.
    -Trans fluid change
    -Full wash and interior detail.
  12. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    Are you using LED bulbs in the headlights also, or just the standard H4 (aka 9003)? If LED, source and link?
  13. Luc_S
    Luc_S Junior Member
    Poland
    Just overhauled the reverse camera: tried to polish heavily scratched lens with 2000 and 5000 water sandpaper, then used a polishing compound for headlights. The effect is very moderate, lens is made of glass, so special glass polishing compounds would do much better job. Adjusted focus. Now I got much better image than before :) (it was very soft and unsharp - beware: softness and unsharpness are two different things).
  14. rodri9o
    56
    22
    NY
    LED for all accessory lights interior (dome, maps, door convenience lights, etc) as well as license plate lights, back up lights, and brake lights.
    For headlights my Prius uses the HID's, so I'm using the standard HID bulb ($180 at dealer, $27.00 on EBay)
  15. Knightrider
    Knightrider Member
    149
    36
    Kansas
    I just upgraded to an 05 rear Matrix sway bar- its amazing the difference it's had. Swapping thr front later in week. Front is from an 05 Celica.
    NOLA_Akita likes this.
  16. Knightrider
    Knightrider Member
    149
    36
    Kansas
    What wheel setup is this??
    Suspention?>
  17. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    do you mean 05 corolla? if it is a celica bar, what is the diameter, and let us know if it does fit.
    SFO likes this.
  18. Knightrider
    Knightrider Member
    149
    36
    Kansas
    Its a solid Celica bar- I will let everyone know.
    The rear Matrix bar has already improved the perceived suspension lift quite a bit.
    Jonathan L and SFO like this.
  19. 69shovlhed
    2,170
    752
    Delaware
    damn, that would be great news if the celica bar fits. its got to be stiffer than the corolla.
  20. Knightrider
    Knightrider Member
    149
    36
    Kansas
    I am hoping I will be able to use a lift and get it swapped soon.
