2014 Prius 19k miles P0A0F P3190 P0401
Discussion in 'Gen 3 Prius Main Forum' started by Sharnold, Sep 12, 2019.
  1. Sharnold
    Sharnold Active Member
    394
    123
    Alabama
    Upon inspection with techstream hybrid battery is ok as so is the map mass and throttle body they all are spotless no oil in the intake or on any components so I'm leaning more on the P0401. When you crank the car idles up then back down rattles out then dies. You can however put the car in drive and take it up the road with no loss of power or any issues. This is only at start up and shutdown. Any ideas? Also the car was wrecked in the front end so has a rebuilt title.......
    #1 Sharnold, Sep 12, 2019
  2. Sharnold
    394
    123
    Alabama
    Heres the current DTC issues any diagnostics needed I can take a picture and send. Sorry my camera had oil on it 20190912_063121.jpeg
  3. Sharnold
    394
    123
    Alabama
    I had a couple of cylinder misfires also I'm beginning to lean towards the EGR code is causing the P3190
  4. Sharnold
    394
    123
    Alabama
    Vsv line was off on the intake after putting it back on and clearing the dtc same issue. Must the ecu be recalibrated or do I need to proceed to egr and intake cleaning?
  5. bisco
    51,027
    how do you get so many newer cars with problems? i think you get more than we see across this entire board.
    Sharnold likes this.
  6. Sharnold
    394
    123
    Alabama
    Lol other than the dealerships I'm the only person in a very large area that works on them. Alot of mine are rebuilt title cars. I've also got two wrecked Gen 2 Prius at my shop being painted and repaired that we bought totalled with low miles. The only things the other shops will do is standard maintenance or change out a battery. I also go to other shops if they have any issues. I repair diesels and other vehicles as well. This is also not my full time job. 20190912_112319.jpeg
    RMB, davecook89t and bisco like this.
  7. Sharnold
    394
    123
    Alabama
    Heres the conundrum after cleaning the egr pipe and checking the egr valve that by the way works flawlessly I cleared the dtc codes drove the car 10 miles no issues no dash lights. As soon as I pull it into the garage to park it engine starts rattling and bucking violently. Only has one dtc P0101 mass air flow sensor any ideas considering its brand new
  8. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Connection is secure and seated?
  9. Sharnold
    394
    123
    Alabama
    Yes its completely seated and clean with an accompanying P0171. The problem that bothers me was the intense bucking and rattling of the engine
  10. ASRDogman
    ASRDogman Senior Member
    7,116
    3,713
    Maybe double check every connection, and vacuum connections.
    Maybe a vacuum hose is loose, or cracked?
    mjoo likes this.
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Definitely sounds like something is messing up the idle vacuum. Air is coming from somewhere. Or fuel isn't.
  12. Mendel Leisk
    40,470
    You said everything was fine until you got back to your garage? Why would that be: no stop-and-idle on your test drive, or maybe everything fine until it's warmed up??
  13. Sharnold
    394
    123
    Alabama
    No idling issues at any stop signs or turns or misfiring or rough jerking while driving only after I pulled it into the garage and hit the park button did it start and throw the maintenance needed and started rattling. Map was at 13psi last test. No misfires recorded
    #13 Sharnold, Sep 12, 2019
  14. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Does it clear up again if you go back to D or R?
    This is an interesting one.
  15. Sharnold
    394
    123
    Alabama
    No actually it rattles just as bad and dies out in D of course R just cuts it off and puts it on the HV battery..... but if you take off in the car it clears up and will run fine till you return it to park lol like I said a conundrum
  16. Sharnold
    394
    123
    Alabama
    Best bet I'll change the mass sensor out if it doesn't work I'll put the car in maintenance mode to keep the engine running and spray starter fluid to check for air leaks
    mjoo likes this.
  17. Sharnold
    394
    123
    Alabama
    New fun..... changed the mass sensor got 3 new codes I havnt had
    P0102
    P0113
    P0171
    All referring back to the mass sensor...
    Shoot me for fixing rebuilt title cars I'll take a bone if someone wants to throw one too me. Yes the plug is seated Yes the plug is clean Yes the wires are all good on the harness and voltage is correct
    #17 Sharnold, Sep 13, 2019
  18. ASRDogman
    7,116
    3,713
    This might seem silly, but are you sure you got the correct one?
    Did you check for vacuum leaks?
  19. Sharnold
    394
    123
    Alabama
    Yes it's the correct one matching numbers just like the factory denso one. No vacumn leaks ran the car in maintenance mode sprayed nothing.
  20. ASRDogman
    7,116
    3,713
    Maybe the pcv valve or egr valve or both are sticking?
