Windshield Wiper Spray
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hunterxaz, Jan 18, 2011.
  1. hunterxaz
    hunterxaz New Member
    28
    Salt Lake City, UT
    My windshield wiper spray doesn't work. The juice just kind of sputters out, it doesn't shoot out. The tank is full, and the rear-window wiper nozzle works fine. What are some things I can do to troubleshoot this?
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Sounds like something is clogging the washer fluid nozzle hole(s).
    You can try to clear them out with a straight pin or needle. An unfolded
    paper clip may work, but if it doesn't fit without forcing it, STOP. You
    don't want to goober up the hole and get an erratic spray pattern.
    If this doesn't work, you may need to unhook the tube for the washer
    fluid at the nozzle and try to "back flush" the nozzle with some
    water/fluid.
    FWIW, the hole in the nozzle is in a small spherical bead. You can re-aim
    the fliud streams by inserting the pin/needle/clip deeply in the nozzle hole
    and then twisting the bead to re-aim it. Be careful, small changes can
    result in large changes in the spray pattern. (Don't ask how I know. :rolleyes:)
  3. hunterxaz
    28
    Salt Lake City, UT
    I'll take a look tomorrow. I tried the toothbrush + vinegar trick tonight but may need to do a pin. I'll post results.
  4. AvTech72
    AvTech72 Junior Member
    28
    Miami Beach, FL 33140
    Three Touring
    Any results to your issue?
