Dead Battery
Discussion in 'Newbie Forum' started by Shaunt30, Sep 26, 2019.
  1. Shaunt30
    Shaunt30 New Member
    Gillette, WY
    2001 Prius
    Hey guys, I need help with my 2001 Prius. More and more lately, my 12v battery is dead when I get in the car. It only takes 1 or 2 seconds with my jump pack to start it, then it reads full voltage. Anyone else have this problem? Seems to me like it is something simple somewhere.
  2. Skibob
    Skibob Senior Member
    2,912
    1,501
    Northern California
    The only help you need is from a new battery.
    Cheryl A likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,869
    4,814
    Pacific Northwest, USA
    Time to buy a 12v battery... Let us know if you want info about options... Make sure you don't buy an Optima, they don't do quality control and have no concern about re-selling defective batteries and lots of 'em.
    Shaunt30 likes this.
  4. Mendel Leisk
    40,245
    Any car will read around 14 volts once the car is started, regardless of battery status.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Are you personally capable of replacing your 12v battery ?
    Or would you need someone to do it for you ?
    Rob43
  6. bisco
    50,821
    is the gen 1 under the hoody?
    Raytheeagle likes this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Nope, hidden in back...
    Rob43
    Raytheeagle and bisco like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,262
    15,506
    Bay Area, California
    2019 Prius Prime
    There’s only one thing hidden under the hoody:p.
    And he’s loved by the GOAT(y).
  9. Shaunt30
    Shaunt30 New Member
    Gillette, WY
    2001 Prius
    I am plenty capable
  10. Shaunt30
    Shaunt30 New Member
    Gillette, WY
    2001 Prius
    That doesn't explain how it can go for days just fine, then be dead for a few, then be fine again.
  11. bisco
    50,821
    and he should have kept ab until something was proven :whistle:
  12. Skibob
    2,912
    1,501
    Northern California
    The reason is because the 12v battery doesn’t actually start the car, the traction battery does. 12v just boots up computers and can run on very low voltage. What’s your standing Voltage?
  13. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    That "full voltage" may not be coming from the battery, it may be the result of the car trying to charge the battery. You test the battery when the car is running, maybe you're measuring what the car is producing.
    Expired 12 volt battery is the simplest explanation.
  14. Shaunt30
    Shaunt30 New Member
    Gillette, WY
    2001 Prius
    Put a new battery in a few days ago. Wouldn't start this morning without a jump. Voltage was 11.9
  15. Shaunt30
    Shaunt30 New Member
    Gillette, WY
    2001 Prius
    Nee battery, same problem.
  16. bisco
    50,821
    you need to do some testing. take the battery back and have them charge it. then check the voltage after a few hours.
    then install it, check the voltage again and every morning before starting the car, until you're comfortable that its holding near 13 volts, or not.
    if not, you have a defective battery, or a bad charging system.
    Skibob likes this.
