Unable to fill talk completely
Discussion in 'Gen 3 Prius Main Forum' started by Stephan Jefferson, Sep 30, 2019.
  1. Stephan Jefferson
    Stephan Jefferson New Member
    Long Beach, CA
    I just bought a used 2012 Prius Four. The first time I went to fill the tank up it kept stopping like the tank was full even though I had only been feeling for about 5 seconds. The second time I filled it up it filled up just fine. now the third time same issue as the first time.
    I hear there's an issue with the fuel door not being open and that is how I successfully filled it up the second time but it doesn't seem to be consistent. I looked on here for any posts about this issue to no avail. Can anyone help me?
  2. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    Curious if you used the same station and same pump the second time.
    My guess there is too much back pressure on the nozzle when you inserted it into the filler. It happens to me from time to time. If I pull out the nozzle a little bit, there is enough air movement to keep it going. Also try just using the slower fill tab/holder.
    -Spiral
  3. Stephan Jefferson
    Long Beach, CA
    Do you mean the fuel cap holder on the fuel door?
  4. Mendel Leisk
    40,483
    Just editorial: for a few hours you're able to edit the title of a thread you started. Look up near the top, there's a button, forget what it's called exactly, but it's there.
    The door issue is just with 4th gen if I'm not mistaken. 2nd gen had problems with the gas tank having an internal flexible bladder. Haven't really heard of problems with third gen.
    I'd guess it was a touchy gas station pump.
  5. spiralhelix
    255
    217
    Illinois
    No. The little tab that sets the speed of the gas flow. Usually there are 2-3 levels to control the speed. The faster it pumps the more air is needed to keep the pressure from shutting it off. If you use the slowest setting, it will pump better.
    -Spiral
  6. Stephan Jefferson
    Long Beach, CA
    Where do I find that?! That sounds like it is my issue. The previous owner must have it set that way.
  7. spiralhelix
    255
    217
    Illinois
    it's a nozzle thing, not a car thing. The filler hole can be tight depending on the actual size of the nozzle. If one is just slightly bigger, it won't allow for as much air to flow.
  8. Stephan Jefferson
    Long Beach, CA
    It happened at Costco... Both trips 2 and 3. so one time I filled up at Costco and it went off without a hitch the other time I filled up at Costco and I had issues.
  9. spiralhelix
    255
    217
    Illinois
    it really doesn't take much back pressure to set it off. and there are a lot of other variables that can be in play. If it stops sooner than you'd like, pull the nozzle out slightly and slow down the flow. I doubt there is anything wrong with your car itself.
    Stephan Jefferson likes this.
  10. bisco
    51,032
    try pumping as slow as possible
  11. BZzap!
    BZzap! Senior Member
    1,607
    878
    Make sure the fuel nozzle is seated firmly against the fill neck of the car. Anytime the seal is broken between neck ant the nozzle it will trip off. I push the nozzle into the fill neck a substantial amount to assure a good tight seal before I trigger the nozzle.
  12. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    How appropriate. The long lines behind you at Costco are going to just love that. But they'll understand. It's a Prius.
    In case it might help, on a different, old car of mine there's a similar problem and the trick is to basically have the nozzle rotated 180 degrees from its normal orientation. I.e. put the nozzle in, then rotate 180 degrees. Possible on that other car because the filler is in the top of the fender, not sure how possible it is here. But maybe trying a little twist would allow you to maintain speed.
  13. bisco
    51,032
    just think of the line if it was a bev :p
  14. CR94
    CR94 Senior Member
    2,662
    1,149
    Northwestern S.C.
    Many pumps nowadays refuse to slow down much, if at all.
  15. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Sand pounders are made on that situation.
  16. bisco
    51,032
    try sitting at a station on the jersey turnpike :sleep:
  17. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    Do not try ti fill a v to the top.... it throws the gas gauge off..... I made the mistake of seeing how much gas I could get in.....
    Just put gas in till pumps shuts...don't keep putting small amounts in till way at the top....
