Gas gauge stuck at Full
Discussion in 'Fred's House of Pancakes' started by Deleted member 111882, Oct 2, 2019.
  1. It’s stuck at full since the end of August. This is also when they installed a work charger, just recently. Since then I’ve been driving to and from work, doing occasional shopping, and some local trips.
    But that gauge is still showing a full tank.
    What should I do... :)
    bisco and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Just drive it(y).
  3. DavidA
    2,345
    1,821
    Chicago western burbs
    I would take it back to the dealer and raise a ruckus. There just has to be something wrong with it.
    Mine was stuck at 9/10th's without budging since December of last year. Then I drove it to Maine and back a couple weeks ago, and that seemed to have fixed the problem. I'm not sure what I did, but it has been much lower and/or much higher since.
  4. Trollbait
    12,543
    On a serious note, a coworker, and hundreds of others, got stranded on the side of the road when they ran out of fuel. Gas contaminated with too high sulfur had reached the gas stations, and it broke the fuel level sensors in the cars' tanks.
  5. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Driving all EV? Then it is perfectly normal. Don't worry, comes winter, you will be seeing some decline on gas level. You have to use gas to heat your car! ;)
    #5 Salamander_King, Oct 3, 2019
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    My advice would be to drive to San Diego, CA. Nice climate, nice people, too far to go to find electricity all the way.
    https://goo.gl/maps/9KRxKecKgXxHuEfh8
    Optionally you could drive back to Maine, but why?
  7. bisco
    51,965
    move it from fhop to prime:p
  8. DavidA
    2,345
    1,821
    Not always true. The car has a two-stage heat pump that can work perfectly well if you don't tax the car's electrical system too much (rear defogger, front defogger, 16 degrees F or lower).
  9. Tideland Prius
    16,559
    Winter is coming. You can trickle burn through the season.
    Salamander_King likes this.
  10. DavidA
    2,345
    1,821
    "trickle burn" should be in the Prius term glossary from now on. Good one!
  11. Salamander_King
    11,019
    8,954
    New England
    Maybe not every winter day, but since he lives in Maine, I am sure he will have some winterly days when his ICE will kick in. For me, during Jan-Feb, when I first turn on the car in the morning, I could not keep the ICE off no matter what I did, even AC completely off.
  12. DavidA
    2,345
    1,821
    Skylis' upcoming thread in a couple months will be "Gas gauge has moved!" Yes there are mornings when the Prime just does gas. And that's OK. Last couple of winters the days it did auto-gas start numbered less than 20 in the Chicago weather. I can live with that until it is Model Y time.
  13. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    I don't know what you should do LOL I'd go camping...
