Dash Lights Not Working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DoveFlys, Sep 29, 2019.
  1. DoveFlys
    DoveFlys New Member
    Pennsylvania
    Spilled glass of water down dashboard by instrument panel. Now only lights on right side of panel work. No lights on left side of panel work.
    What are all possible causes of this and what would be the repair process?
    Thanks
    Lou
  2. StarCaller
    StarCaller Senior Member
    1,271
    722
    Cedar Crest, NM, USA
    the water....? j/k
    guess you have to take it apart & literally hang it out for drying /
    (might not be a bad idea to give it a splash with pure alcohol after you have it out_
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Get a used one on eBay for 100
  4. DoveFlys
    DoveFlys New Member
    Pennsylvania
    Only problem with that is this happened months ago and I am sure has already dried.
  5. DoveFlys
    DoveFlys New Member
    Pennsylvania
    What is the part I would buy and why would only half the lights on dashboard work? Any idea?
    Thank You.
    Lou
  6. DoveFlys
    DoveFlys New Member
    Pennsylvania
    What is the name of the used part I'm looking for?
  7. bisco
    51,021
    combination meter. it's a huge job, and you need to get the odometer set legally, iirc
  8. ASRDogman
    ASRDogman Senior Member
    7,114
    3,713
    HOW in the world did you do that?
  9. tankyuong
    1,555
    661
    Central MO
    Only if you sell the car
  10. DoveFlys
    DoveFlys New Member
    Pennsylvania
    Is there ANY possibility it is something other than the combination meter?
  11. bisco
    51,021
    you could try looking for fuses, maybe they are separate, idk.
    call matt at texas hybrids and ask his opinion, he rebuilds them.
