Did I miss anything?
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Oct 10, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    One of the better reviews I've seen lately. But he missed the HUD, heated steering well, rear USB ports, and sun visor extensions. Did I miss anything?
    Old Bear likes this.
  2. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Nothing said about the GPS display and functionality including ability to get traffic information and map updates. Is this unchanged or has it been improved?
    It looks like the only changes to the 2017-2019 models are the addition of the middle rear seat, Apple car play, black trim on the steering wheel and shifter, and a more convenient location of the switches for the heated front seats.
    No mention of giving up all the cell-phone remote functions like climate control pre-conditioning, car locator, charging monitor and management, charge station locator, etc... and the beloved ECO dashboard sheep.
    I did like the explanation of the trade-off between EV range and overall MPGe efficiency.
    Marine Ray likes this.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    AoA’s reviews are almost always super-thorough. I like them a lot.
    noonm and Marine Ray like this.
  4. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Quite refreshing to watch an actually informative car review video that's full of facts rather than subjective blather.
    However, things he missed:
    - No spare tire, still only goo tire
    - No mention of the plug compatibility besides voltage (i.e. 120v v 240v) (would be nice to show it getting plugged in)
    - Would have been good to mention the wide variation in EV range based on season (i.e. lower in winter, higher in summer) and based on driving efficiency
    These are mostly just nit-picking as, overall, its a very good review. Also, the nice looking black interior makes me wonder why Toyota choose the god awful white interior trim in the first place.
    #4 noonm, Oct 11, 2019
    jerrymildred and Marine Ray like this.
  5. Old Bear
    712
    1,050
    Does the 2020 model include the "advanced parking guidance " system? I only tried it once or twice on my 2017 and found that it was more trouble than it was worth -- not ready for Prime time, as they say.
    It always seemed to me that this was an experiment by Toyota to see if "self-driving" features were something owners wanted. If Toyota improved this system, great; if not, no big deal.
  6. DavidA
    2,344
    1,820
    Chicago western burbs
    New longer traction battery warranty on the 2020 too. 10 yr./100K miles.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Actually, 10/150,000
  8. mr88cet
    2,313
    1,335
    Austin, TX
    I saw the announcement, and saw the 10-year and 150Kmile numbers. What I can’t recall seeing was how much degrade (in %capacity or range) it warrants against in that period.
    jerrymildred likes this.
  9. jerrymildred
    11,517
    14,148
    Tampa, FL
    I don't think that they ever gave any numbers for that for either the PiP or the Prime. If I had to guess, I'd guess they would say that if it doesn't throw a code, it isn't broken.
    Raytheeagle and mr88cet like this.
  10. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Looks like they are taking the CARB-state warranty coverage of the battery nationwide.
  11. jerrymildred
    11,517
    14,148
    Tampa, FL
    Yup! And it's transferable, unlike some of the competitors' HV warranties.
  12. Salamander_King
    Salamander_King Senior Member
    11,016
    8,947
    New England
    I am in CARB state, so I have a 10 years/150 K battery warranty on my 2017 PRIME.
    Old Bear and noonm like this.
  13. mr88cet
    2,313
    1,335
    Austin, TX
    do not know either, but that’s a reasonable guess. So, I suppose the question is “what could throw a code?” So presumably that’s at least partly a function of what all the battery has sensors to detect...
    #13 mr88cet, Oct 12, 2019
  14. Old Bear
    712
    1,050
    Take a look at the video about the Prius Prime battery by John Kelly of the Weber automotive program:
    At 37:30 into the hour-and-a-quarter long video, Professor Kelly explains the Prime's battery ECU which monitors the battery right down to the performance of individual cells.
    This is a diagnostic screen of a Prius hybrid battery (not a Prime) which shows the kind of block-level detail which is available:
    A similar diagnostic for the Prime should show any problem cells which were not functioning at a level consistent with the rest of the battery -- but whether or not that would constitute the basis for a warranty repair is a good question.
    This is probably why so many automotive technicians decide to go back school to earn their law degrees.
  15. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    I have used the parallel parking system many times on my 2017 Prime and for me it has worked very well.
  16. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    On a tangentially related matter: If Prime's battery is indeed 8.79 kWh, shouldn't its electric-only range be quite a bit longer than 25 mi? Is Toyota lowering people's expectations to avoid disappointment, or the 8.79 kWh is a theoretical figure and not the available capacity?
  17. jerrymildred
    11,517
    14,148
    Tampa, FL
    8.79 is the actual capacity. In order to protect the battery, Toyota does the same on the Prime as with all their other hybrids by not letting the car dip into the bottom of the battery's charge or letting it completely fill the battery. Useable capacity is around 6.8 kWh or maybe a little more. If it let the car use the full battery, you could go a lot farther on EV, but at the expense of replacing a very expensive battery way more often that you would like.
  18. Dimitrij
    405
    202
    Virginia
    Oh, that ... didn't the same confusion occur with the "Tesla killers" iPace and e-Tron, when they were reported to have "90 kWh batteries", which turned out to be good for 234 and 204 miles respectively instead of 300 miles many buyers had estimated, based on the interpolation of the TMX and TM3 mi/kWh values. From what I remember, one of the reasons of such poor performance was that the usable battery capacity was a lot lower than the declared 90 kWh.
  19. Salamander_King
    11,016
    8,947
    New England
    From most reports and my own finding with my PRIME using Hybrid Assistant, the actual usable battery capacity for the full EV range is more like 5.5 kWh.
    Dimitrij likes this.
  20. Dimitrij
    405
    202
    Virginia
    Thanks! The figure makes perfect sense, because (a) 25 mi on 5.5 kWh is a Prius should get with pure electric traction, and (b) 5.5 kWh vs 8.8 kWh implies a good 15-20% cushion on the low- and high ends of the battery's SoC.
    Salamander_King likes this.
