2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Mendel Leisk
    40,471
    Dealership must have those?
  2. ASRDogman
    ASRDogman Senior Member
    7,116
    3,718
    You know, you will find it AFTER getting another one. :)
  3. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Absolutely. Just like I couldn't find my 12 point 10mm socket untill I borrowed one from neighbor and did the job.
    Then it showed up in a spot I looked 3 times
    Tim Jones and ASRDogman like this.
  4. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    Use a pressure washer? Water shouldn't scrape the valves. You'd need to clamp them down somehow.
    Pixel XL ?
  5. Raphael Muscarelle
    661
    222
    Change transfluid. 240k maybe should do it every 125k
    #105 Raphael Muscarelle, Oct 21, 2019
    RMB, Mendel Leisk and mikey_t like this.
  6. Raphael Muscarelle
    661
    222
    Guy next door who is head rebuilder in previous life agrees with me leave it. Too late now anyway. It's together.
    mjoo likes this.
  7. Raphael Muscarelle
    661
    222
    After the fact I thought it would be interesting to soak them in that fuel additive that's supposed to remove carbon. That would be a definitive result of it works or not.
    mjoo likes this.
  8. Raphael Muscarelle
    661
    222
  9. bisco
    51,027
  10. Raphael Muscarelle
    661
    222
    Timing chain. Ahhh it looks like this is what they are talking about IMG_20191022_153103.jpeg IMG_20191022_153057.jpeg IMG_20191022_153050.jpeg
  11. Raphael Muscarelle
    661
    222
  12. Mendel Leisk
    40,471
    I can post a video link in a mo, those guys with the quicky head gasket change. They spell out the chain orientation very clearly.
    Robert Holt likes this.
  13. Raphael Muscarelle
    661
    222
    I'll watch but I think that's correct. Trying to put on other mark hits valves into pistons.
  14. Mendel Leisk
    40,471
  15. Raphael Muscarelle
    661
    222
    Manual has headbolt loosing order.
  16. Raphael Muscarelle
    661
    222
    That's real ugly in that engine.. ridges in head gasket get pressed out with torque of the head.
  17. Raphael Muscarelle
    661
    222
    Hope they didn't leave all that residue on the head and block. Also need to measure more then just down the middle of head for flatness
  18. Raphael Muscarelle
    661
    222
  19. Raphael Muscarelle
    661
    222
    Have cam A sensor saying over advanced and when rev the back side of rev has what sounds like a chain rattle
  20. ASRDogman
    7,116
    3,718
    Are you saying you have the motor back together and in the car? And have it running?
