The day that toyota switches from making 2006 prius autos to 2007
Discussion in 'Gen 2 Prius Main Forum' started by stanleyjohn, Sep 13, 2006.
  1. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    May be a silly question but id like to see if anyone knows! What is the date that toyota stops making the 06 and starts the 07.Is this also the date that the toyota web site and others start using the 2007 build and price?Kinda curious on the date the last 06 rolls off the assembly line.
  2. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Already happened. I think if you do a search it's posted on this forum somewhere. Maybe check the "stickies" at the top.
  3. Tideland Prius
    16,496
    They're already building 2007s for October deilvery.
  4. NuShrike
    NuShrike Active Member
    1,378
    If you're thinking of the Touring Edition, they've been making it since at least 2003.
    What other changes is the 2007 edition is supposed to have?
    edit: since 2003 in Japan.
  5. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :rolleyes: QUOTE: " If you're thinking of the Touring Edition, they've been making it since at least 2003. "
    REALLY? I wasn't aware that there was a "Touring Edition Prius" in 2003. Perhaps that's a misprint.
  6. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    I think NuStrike meant they have been making the Touring edition in JAPAN since then.
  7. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 13 2006, 11:46 PM) [snapback]319309[/snapback]</div>
    Checked the Toyota website. They are still featuring the 2006 Prius. Some other Toyotas are being advertised as 2007 models.
  8. Tideland Prius
    16,496
    <div class='quotetop'>QUOTE(NuShrike @ Sep 14 2006, 12:25 AM) [snapback]319367[/snapback]</div>
    In Canada, we only have ONE change for 2007. The introduction of Magnetic Grey :rolleyes:
    Thanks.... we're now probably the only country with the least amount of options (in terms of packaging AND the number of features available to us)
