2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    Raytheeagle likes this.
  2. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Well the dot is right on the yellow link
  3. ASRDogman
    ASRDogman Senior Member
    7,118
    3,719
  4. The Critic
    3,193
    2,327
    CA
    From the picture, the “nub” on the crank looks like it is past 12 o clock. If you reinstall the crank bolt with the timing cover, do your marks line up with 0?
    iPhone ? Pro
  5. Raphael Muscarelle
    661
    222
    Gonna recheck but it was. Probably looks that way becouse the engine is not at 0. Engine is installed at angle.
  6. Raphael Muscarelle
    661
    222
  7. Raphael Muscarelle
    661
    222
    Another thing that seems to be confusing is that with every 4 turns it seems to advance 3 links. But timing marks continue to line up with land marks
  8. Mendel Leisk
    40,472
    Rewatch, starting around 31 minute mark?
  9. Mendel Leisk
    40,472
    Seems like the chain's a bit off on the left side. Just hasn't settled onto the teeth, or??
    Robert Holt likes this.
  10. ASRDogman
    7,118
    3,719
    Maybe that tensioner is weak and needs replacing?
    mjoo and Mendel Leisk like this.
  11. Mendel Leisk
    40,472
    Seems like it's a minor misalignment: the engine will run, but it's not that happy.
  12. Raphael Muscarelle
    661
    222
    mikey_t likes this.
  13. Raphael Muscarelle
    661
    222
    Nope jumped tooth when first start.
    Engine should be turned by hand to take our slack in chain.
    Robert Holt and Mendel Leisk like this.
  14. Mendel Leisk
    40,472
    Sounds good. (y):)(y):):cool:
  15. ASRDogman
    7,118
    3,719
    Rookie mistake. :) Happens to ALL of us! :)
  16. ASRDogman
    7,118
    3,719
    Sounds brand new! Great Job!
  17. Raphael Muscarelle
    661
    222
    Thank you much.
    I think it was worth it lapping every valve.
    Starts smoother and stops smoother then it has since I've owned it.
    Thank God it is done.
  18. Raphael Muscarelle
    661
    222
    Meh it's been 20 years since I've rebuilt anything. Also other people's advice on internet is lacking.
  19. ASRDogman
    7,118
    3,719
    It doesn't get easier with age! 184,000 miles and mine is still running fine.
    I think because the previous owner did a lot of highway driving and rarely went over 65mph.
    I cleaned the egr system around 125,000 miles and it didn't look bad at all.
    I would like to do one though, just to do it. Everything I've done on the Prius as been super easy.
    I'm glad you are back up and running!
  20. douglasjre
    douglasjre Senior Member
    2,090
    698
    Null, NL
