windshield wiper fitment
Discussion in 'Gen 4 Prius Main Forum' started by hottubbrad, Oct 28, 2019.
  1. hottubbrad
    hottubbrad Junior Member
    I stopped at my local car parts place and none of their replacement wipers would fit. He had none that had the little protruding tab. Are there any jobber wipers that fit?
  2. husami
    husami Junior Member
    Cincinnati, Ohio
    The handle made by Toyota is going to be better than any other. I would only replace the refill.
    28" Driver Side
    16" Passenger Side & Rear
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Are you asking about a PRIUS? - your profile shows " upload_2019-10-29_10-29-7.png "
    Prodigyplace likes this.
  4. husami
    Cincinnati, Ohio
    I measured the wiper blade insert width to be about 6mm so I think if you can find this width and the correct length it should fit. I got a replacement coming soon. Also, I have tried the silicone inserts and they seem to last longer.
  5. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    I replaced my wiper blades with refills from the dealer.
    Extremely hard to install.
  6. booke02
    booke02 Active Member
    391
    415
    Israel
    I replaced my wiper blades with refills that I bought online - I found it relatively easy to replace the blades. ;)
  7. husami
    Cincinnati, Ohio
    How many did you replace? Could you reference the part number?
  8. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Replaced both.
    # 85214-78010
    # 85214-47110
  9. Prodigyplace
    12,617
    11,804
    Central Virginia
    For "Other Non-Hybrid"??o_O
    No we cannot.
    If I assumed incorrectly, please update your profile.
    alanclarkeau likes this.
  10. RRxing
    RRxing Senior Member
    2,553
    1,825
    NEPA
    Inserts are simple to replace. Be aware that the rear wiper insert is also 16", but has a different type of "groove" to attach to the blade, hence a different Toyota product number:
    RUBBER, WIPER, RH 85214-78010
    RUBBER, WIPER, LH 85214-47110
    RUBBER, REAR WIPER 85214-47010
  11. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Prime has a different
    Had 2010 and 2015 which were easy to install
  12. husami
    Cincinnati, Ohio
  13. Prodigyplace
    12,617
    11,804
    Central Virginia
  14. Salamander_King
    Salamander_King Senior Member
    11,020
    8,955
    New England
    OEM wipers on my PRIME are going for the third winter. They are the same OEM wipers (no rear wiper on PRIME) found on Gen4. My car has been always parked outside in direct sun during day and in freezing cold with ice and snow in winter. But, so far they are still going strong. I did order replacement OEM wipers and wiper blade refills from a dealer early on, but so far no need to use them yet.
    Here is the profile of the OEM blade. See this thread: Wiper blade refills | PriusChat
    #14 Salamander_King, Nov 11, 2019
  15. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Let us know when you install them.
    I thought the were more difficult to install than on my 2010 or 2015
    tucatz and Salamander_King like this.
  16. Salamander_King
    11,020
    8,955
    New England
    Sure thing if I remember it. I just don't know when I will be needing to replace my original OEM wipers. It is still working flawlessly even after two years. For my previous Gen3, I replaced with after market wiper blade. Never had to use a refill rubber.
    Since attaching OEM wiper blade using the snap on attachment is so much easier, I also bought a set of OEM wiper blade at the time I ordered rubber refills. If I need to replace current wipers, I will just install them first, then work on the refill onto the old blade at my leisure time, and keep them as spare.
    Pdxprimeguy and krmcg like this.
  17. douglasjre
    douglasjre Senior Member
    2,196
    731
    Null, NL
    are OEM silicone?
  18. Salamander_King
    11,020
    8,955
    New England
    No, they are rubber.
  19. douglasjre
    2,196
    731
    Null, NL
    I'm changing wipers on these things every 12 months. Tired of buying so many/keeping stock on shelf. What do you think of silicone inserts?
  20. Salamander_King
    11,020
    8,955
    New England
    I never had to change the OEM wiper on the 2017 PRIME over 2 years. This with car always parked outside, and wipers often frozen on the window during winter. I bought the OEM replacement a few months after buying the car but never had to use it. I traded my 2017 PRIME to 2020 PRIME a few months ago. I still have the OEM replacement wiper blades and rubber inserts, but I don't think I will be needing to change them if they are the same as 2017.
