Latch on back seat driverside will not release
Discussion in 'Gen 2 Prius Main Forum' started by John Miller123, Nov 17, 2019.
  1. John Miller123
    John Miller123 Junior Member
    Puyallup WA
    Does anyone know I can get drvers backseat to release on 2005 prius? It seems I have to pry it somehow
  2. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Welcome to PriusChat!!
    Have you already tried pushing the small button on the top corner of the seat?
    Also try pushing (or maybe pulling) on the seat back while depressing the button, this may help relieve pressure on the latch.
    Raytheeagle likes this.
  3. John Miller123
    Puyallup WA
    Tried both of those still no luck
  4. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Does the drivers side button depress to the same depth as the passenger side button?
  5. John Miller123
    Puyallup WA
    No, I think it is a broken shaft. Is there another way to get to latch?
  6. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,002
    Yep.
    They can get finicky. Pull the plastic surround around the release button off. Then lift the button and pull it forward before pushing it down. You can feel when the button hits the right spot.
    I have learned a couple of tricks after replacing a few hundred batteries.;)
    srellim234 and SFO like this.
  7. John Miller123
    Puyallup WA
    Worked like a charm thank you
    srellim234 and strawbrad like this.
