Apps to check hybrid battery status
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Siber Pir8, Dec 2, 2019.
  1. Siber Pir8
    Siber Pir8 Junior Member
    55
    UK
    Hi all are there any good apps to check the high voltage battery block levels?
    I have used Dr Prius and got the following results.
    Which blocks look worrying, at 32 secs and 39 sec are where I try to accelerate but the car hesitates.
  2. George W
    George W Senior Member
    911
    514
    San Antonio
    Torque and Hybrid Assistant are also capable of monitoring the HV Battery, but the app you are using is going to provide you with your best hybrid battery Intel.
    Did you perform the specific battery test(accelerating and then decelerating )?
  3. Siber Pir8
    55
    UK
    I tried to, I was in traffic, and only at 32 secs and 39 seconds I was accelerating briefly.
  4. George W
    911
    514
    San Antonio
    A large empty parking lot is good.
  5. davecook89t
    davecook89t Senior Member
    1,076
    812
    Washington State, Florida
    Four Touring
    The way the reported values are bouncing around, I would expect that you have corrosion problems on some of your connections, as well as possibly some bad modules. You probably need to open up the case and take a look (or have someone else do it).
  6. Siber Pir8
    55
    UK
    This was accelerating and braking and accelerating and braking again on a straight road.
  7. George W
    911
    514
    San Antonio
    What result did Dr. Prius interpret for you?
  8. Siber Pir8
    55
    UK
    This was the hybrid assistant app results accelerating and braking.
