New $$$ software that runs Toyota techstream on your PC
Discussion in 'Generation 1 Prius Discussion' started by orange4boy, Mar 19, 2010.
  1. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Which hand held did you get?
  2. LEVE
    LEVE Member
    191
    97
    On the Willapa
    I purchased the Denso Toyota Hand Held Intelligent Tester 2. Prices vary, so shop carefully. Also make sure it csomes with the software needed for your Prius. This will give you an idea of what you're looking for:
    Ebay Listings
  3. gittarpikk
    gittarpikk Junior Member
    59
    East Tennessee
    2002 Prius
    I
    Hi Chapman.. you've helped me a few times and Bob Wilson has helped me immensely years ago on my old 2002 Gen 1.
    A little current history since I have been on PC. I have rebuilt the traction battery several times and always had a notebook with xp in it running TechStream minivci. But about a little over a year ago, the AC condense drain came unplugged somehow and filled the back floorboard with about 2 inches of water before I knew it and guess where the notebook was... yep.No more nice troubleshooting tool. Long story short, Explorer tranny broke so I bought a 2011 Prius and in maybe 6 months wife totaled it due to not seeing well(failing cataract surgery) and not saying anything (plus the beginning of Alzheimer's). Bought a 2010 Prius V for me to use in work and she just waited on me to rebuild the traction battery again while we got here through the surgeries etc). I got the battery rebuilt and the computer seems happy now but need to really take a look as to why it wasn't happy for a while after the rebuild.
    Now the problem.
    I now have a dell Inspiron 6000 running XP I just bought to set up another TS on. I remember a software called xhorse but don't have a clue as to how I had to install it. I can't seem to find much online on how to install that doesn't have to crack. Don't think I had to do anything except the xhorse and a file. but that may have come with the cable (which should still be OK). Not sure where the disc was if there was one.
    Is there any tips, links, pointers I might get from you on what I need to do to get TS on this old XP I bought specifically for this. Unfortunately, I wasn't aware TS could be run on win 7 or I would have bought a win 7 laptop.
    BTW, absolutely love the JBL sound on the Prius V, Bluetooth (for maps and playing my playlist on Amazon music)backup cam and especially the 49-54 MPG(depending on if summer or winter) I get on my 250 miles/day route over the typical 40-45mpg with the 2002. (still like the form factor of the 2002, better visibility and higher ground clearance). Each has its own advantages and disadvantages.
  4. gittarpikk
    59
    East Tennessee
    2002 Prius
    I
    Update:
    Yipeee!... I knew I had to have that minivci software somewhere...! I searched several computers and found the files (I had copied off the original VCI xhorse disk) on my office computer. Took a while as XP is extremely slow on the Dell 6000 laptop but I did get the files copied via the SanDisk USB drive.. I had no clue which file to install, but gut feeling was I probably chose what looked like the latest version. That folder had only two files.(the MVCI driver install setup and the main app file) I read somewhere to install the driver first and not plug anything up yet. The diver install went as planned (seems like there was a readme file in one of the folders which I used as a model). Then installed the main app. I'm now looking at what seems to be exactly what I used on the old XP laptop. As far as I know, success, but will have to locate my Mini-VCI cord to see if it links up like it did on the old XP. I expect it should.
    Now on the bright side, I have Google dive links for all the files which may help someone get the program back on their XP if needed.
    I'll update again once I get time to locate the cord and put it to the test. At this point, I'm very confident this is going to work. as it did before,
  5. gittarpikk
    59
    East Tennessee
    2002 Prius
    I
    Geez what a few years does to a brain... Need tips on getting this old Win Xp running TechStream again
    Update
    Well I bought a 3 year traction battery from Green in Nashville and they came out to install it.
    That was expensive but the battery issue is now history.
    I have a new issue
    The AC works great, and nice and cold after paying 2 different places to attempt to repair the issue but still noy fixed.
    Most of these places just want to 'throw parts at it' witrh an open budget and just see if it fixes it. So I decided to fire up my old Win XP laptop and run the TechStream for diagnostics.
    Well long story short, it had worked fine on that machine but battery died, and after new battery, I tried using it to diagnose a couple gen3's but never got it to connect to car. changed versions and now can get it to run. Seems to want me to register, etc. I think the version change wiped my old install and the keys were no longer good. I have the little install disc and the files on it on the XP . I just need to know how to reinstall it so i can run it on the old Gen 1. (still a great car, I preferred to drive over the Gen 3) but looking for clues as to why the AC works fine until it gets to around 80+ degrees and sits for a little bit, then starts kicking out the compressor and I have to wait a couple minutes to reset it. Guages read around 70 on low and 150-200 on high and climbs to around 80+ when sitting and I can force it to kick out by turning off. I suspect the two speed AC fan not running at high speed or a faulty expansion valve which is a bugger tio get to in this gen.
    Looking to find some clues in TS... or maybe someone that may have a clue as to its AC issue. AC works gerat otherwise...but a pain when it gets hot.
  6. dabard051
    dabard051 Tinkerer-in-Charge
    258
    94
    Rochester, NY USA
    2002 Prius
    Gittarpikk, sounds like the AC compressor is working okay, but do have a look at the AC compressor clutch. It's accessible when you remove the passenger front wheel, just under the water pump. It's possible that (1) the drive belt is old,, dried and cracked, and under load slips or (2) the clutch plate itself slips when it should be sticking (electromagnetic), due to buildup of debris on the AC compressor clutch face due to wear, etc., or (3) both (1) AND (2).
    So if the problem shows with the AC LED blinking when the AC is needed to work hard, give this procedure some consideration.
    There are PriusChat threads that discuss adjusting the gap between clutch face and plate with a Toyota shim kit, but I've not found gap adjustment to be necessary. Just need to clean both the clutch face and pull-in plate really well with isopropyl alcohol to get rid of the dust and debris.
