Bought a 2012 For $700
Discussion in 'Gen 3 Prius Main Forum' started by Cosmo Tigato, Dec 2, 2019.
  1. Mendel Leisk
    40,457
    Boy it's real easy snaking that ATF funnel hose through, with the engine out. :ROFLMAO:
    Dramatic pictures; that's a tall drink of engine. (y)
    rbdigital, J1050, Bay Stater and 2 others like this.
  2. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    Thank you for the pictures!! Man, that cvt fluid is DARK. Maybe I missed it, but how many miles on the Prius?
  3. Cosmo Tigato
    Cosmo Tigato Active Member
    198
    362
    Oregon, USA
    208,784 miles
    I wonder if it was ever changed. Yucky!!!!
    New Engine has 93,000 Miles
    #43 Cosmo Tigato, Dec 21, 2019
  4. b100
    b100 Member
    144
    75
    Netherlands
    So what did you do to unplug the ac compressor?
    Did you just disconnect the lines or dis you took it to a shop to get the gas out?
  5. Mendel Leisk
    40,457
    @b100 As far as I know AC line disconnect is not necessary with engine removal: the compressor can be unbolted, ditto for some line brackets, then just pull it away, maybe tie to something.
    b100 and Cosmo Tigato like this.
  6. Cosmo Tigato
    198
    362
    Oregon, USA
    I just used a bungee cord and hung it out of the way. :)
    #46 Cosmo Tigato, Dec 22, 2019
    b100, Bay Stater and Mendel Leisk like this.
  7. Cosmo Tigato
    198
    362
    Oregon, USA
    Got the engine all bolted in and now connecting all the hoses, wiring harness and fuel line.
    All that's left to do is wipers and some plastic parts.
    Last BOLT is in!!!!
    Just have to put in the Super long life Toyota Coolant (Bleed all the air out)
    and some Mobil One 0w-20
    Ha ha ha You can see the old engine in the back of the picture
    Bay Stater, VFerdman, mikey_t and 4 others like this.
  8. ASRDogman
    ASRDogman Senior Member
    7,111
    3,713
    Are you going to be able to start it tonight?
  9. Cosmo Tigato
    198
    362
    Oregon, USA
    Yeah, I had to clear the previous codes
    and charge up the 12v battery.
    I Drove it around the block a few times.
    No Codes.
    So Far so good.
  10. ASRDogman
    7,111
    3,713
    THAT'S GREAT!!! I hope everything works perfectly for you!
    And now you can rebuild the original motor! :)
  11. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    I need to pull my trani. How many bolts was it and any suggestions on their removal. Thanks in advance!
  12. Cosmo Tigato
    198
    362
    Oregon, USA
    2 bolts on top
    2 bolts where the starter cover plate is (because there is no starter)
    3 on the bottom
    and 2 on the back
    -So 9 all together-
    SFO and Tim Jones like this.
  13. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Wow! Your pictures make the engine swap look sooo easy. Hope that the new engine works out well for you! Please keep us posted. Don't know if I will be that ambitious. Just have to take real good care of the engine that I got, LOL. :whistle:
  14. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    You could buy a whole bunch of broken Prii, repair them and have a fleet to put on turo for real cheap. The only catch is that a car has to have less than 130,000 miles and not have a rebuilt or salvage title.
    I wish I could do what you can do I could quit my job and have a huge fleet of Prii
    Making money for me while I relax at the beach in L.A.
  15. hyp3rmil3r
    hyp3rmil3r Member
    120
    94
    Northeast
    Nice resurrection! Sounds like this was a n easy job for you. Really cool to see you got a steal and put some work into it.
    Cosmo Tigato likes this.
  16. Cosmo Tigato
    198
    362
    Oregon, USA
    Lol... yeah,
    The Gen 3 is super easy to work on (compared to the gen 2 or gen 1)
    Rayman2010 and hyp3rmil3r like this.
  17. Cosmo Tigato
    198
    362
    Oregon, USA
    I will try to fix any Prius... It just takes time and tools.
    The best tool is a Toyota Scan tool.(Mini VCI + Tech Stream)
    PriusGuy32 and Johnny Cakes like this.
  18. douglasjre
    douglasjre Senior Member
    2,085
    698
    Null, NL
    How many hours to change the motor out
  19. douglasjre
    2,085
    698
    Null, NL
    And where did you get the best price on an engine and how much did you pay
  20. Cosmo Tigato
    198
    362
    Oregon, USA
    Probably about 6 hrs
    Most of the time is disconnecting Wires and hoses.
    Then reconnecting all the stuff.
    Unbolting and hoisting is fast and easy.
    dig4dirt, J1050, kc5dlo and 7 others like this.
