The Aftermarket Wheel Thread
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Pork_N_Beanz, Aug 13, 2017.
  1. Pork_N_Beanz
    Pork_N_Beanz New Member
    Montreal,QC,Canada
    Post your aftermarket wheels specs and tire size
  2. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    Rims: RAYS Aecros 17 x 7J 5-100
    Tires: Bridgestone Potenza RE760 Sport 215/45R17 image.jpeg
    TheRedRocker and RCO like this.
  3. Jorin
    Jorin Member
    67
    91
    22
    Moon
    Rims: 7,5J x 17 Advanti Racing Raccoon black/polished
    Tires: Bridgestone Turanza 215/45R17 (standard tires)
    #3 Jorin, Sep 5, 2017
  4. Archenemy
    Archenemy Junior Member
    24
    Singapore
    Volks racing CE28
    205/50R17 tyres
    TheRedRocker likes this.
  5. TheRedRocker
    TheRedRocker Member
    47
    46
    Kansas City, MO
    Konig Ampliform bronze
    17x8 +40mm
    17.85 lb
    General G-max AS-05
    225/45ZR17
    21 lb
    Both from fitmentindustries.com
    Stock suspension
    These pictures don't do them justice; they look much better in person. The bright sun makes the wheel gap look worse; I do plan to install lowering springs
    IMG_20191012_130759746_HDR.jpg IMG_20191012_130648120_HDR.jpg IMG_20191012_130637586_HDR.jpg IMG_20191012_130742237_HDR.jpg
    Bruce22 and krmcg like this.
  6. krmcg
    2,592
    2,392
    Whittier, CA
  7. TheRedRocker
    TheRedRocker Member
    47
    46
    Kansas City, MO
    Thanks, color choice was a bit risky with an online order. I am pleased.
    krmcg likes this.
  8. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    bump! post up your set-up guys. I have something in the works in the next month or so with some 8lb wheels. don't want to fully jinx it yet in case it doesnt work out. Want some inspiration to fully commit
    PriusOffroad and krmcg like this.
  9. PriusOffroad
    PriusOffroad Active Member
    108
    170
    Chico, CA
    8lbs!?!? I need details!
    krmcg likes this.
  10. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    Sorry. Didn't get a notification you asked.
    It's a set of CE28N in 15x6.5 +45, 10-spoke design. Almost impossible to find in 5x100 but I found a set DIRT CHEAP . Needs a little work but even after refinishing, still cheap for a forged set. Supposed to be 8.11 pounds but the seller said it's around 3.5kg. Still waiting on it and I'll try to get some weights
    #10 jteran5, Dec 31, 2019
  11. PriusOffroad
    108
    170
    Chico, CA
    Oh man, I just got ridiculously jealous. Talk about find! If you come across another set this is what I’ve been looking for.
  12. The Big Sleaze
    290
    64
    'frisco
    2020 Prius
    Two Eco
    I got a brand new (1000 miles) set of fancy $800 10-spoke factory 2020 Prius 15" wheels and stock tires for sale/trade. See my add in 'for sale'. SF bay area, need to trade for base wheels, so I can install "speedway" solid alum "full moon" hubcaps.
    PriusOffroad likes this.
  13. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    If you're going for those hubcaps, why not a set of gen2 wheels? About 3lbs lighter than the base 19/20 wheel and it's going to be covered anyway. They go for maybe 250-300 from what I've seen tapatalk_1575685518419.jpeg
  14. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    Sneak peek
    15"s are almost impossible to find in 5x100. The larger ones are more common but well over $1.5k 20200102_175816.jpeg 20200102_175802.jpeg
  15. PriusOffroad
    108
    170
    Chico, CA
  16. PriusOffroad
    108
    170
    Chico, CA
    Where’s this for sale section you speak of? Link to ad?
    krmcg likes this.
  17. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    I'm actually going to get them redone in matte black. Kinda partial to the color. Should come out like this 6848e0ae.jpeg
  18. PriusOffroad
    108
    170
    Chico, CA
    Why are you doing this to me!?!
  19. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    Wanted to post my current setup
    -Tire specs: Firestone Champion Fuel Fighter 215/60/15
    -Wheels: Volks/Rays CE28N's, 15x6.5 +45, 65mm center bore- Dark Gunmetal
    - McGard lugs/wheel locks in chrome black
    Car is lowered on Tanabe springs (changing to Tein h.techs next week)
    Front and back, I currently have 10mm H&R wheel spacers with built in hubcentric rings. Swapped stock studs with supplied longer ones. Also using Rays 65mm-54.1 hubcentric rings for the wheels themselves.
    I kinda wish I went with a thicker spacer but then I would have to swap out the studs again... Idk.. 20200129_210509.jpeg 20200212_141315.jpeg 20200212_141321.jpeg 20200212_141332.jpeg 20200212_141344.jpeg 20200212_141403.jpeg 20200212_141410.jpeg
    #19 jteran5, Feb 13, 2020
    EconoModder and krmcg like this.
  20. krmcg
    2,592
    2,392
    Whittier, CA
    outstanding!
