What did you do to your Prime today?
Discussion in 'Prime Accessories and Modifications' started by Raytheeagle, Apr 20, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    You missed the dirty tires.
    iPhone ? Pro
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I only had so much time;).
    But the remnants of my off-roading in Brentwood remain for now:cool:.
    They’ll get cleaned eventually (y).
  3. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Today I took my Prime in for one its freebie Toyota oil change services... All is well.
    It was funny to hear some of the stories that the Toyota master technician told me. The most amusing one to me dealt with the female charging port located on the Prime, it turns out that Toyota had to remove some OE rubber O-ring in that area because the chinese poorly made EVSE charge handles that some people buy were so tight fitting that they would occasionally break the charge port on the Prime. Go figure...
    Rob43
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Not to say a poorly made EVSE could not damage the port, but Toyota removed the o-ring somewhere between the 2012 and the 2013 PiP because the o-ring would fail which made it hard to plug in the OEM EVSE and it wasn't necessary anyway. No Plug-in Prius has had it since. Lots of threads here about it. ;)
    Charger O ring | PriusChat
    PIP charging cable won't click into the car | PriusChat
  5. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    That's funny, and I'm sure what you're saying is very accurate.
    The master tech must have "blended" stories, at one point he was definitely talking about the chinese made EVSE units and how that dealership had seen warranty and non-warranty repair work associated with ill fitting clone charge handles. Then he started talking about that O-ring problem, but didn't differentiate between the two.
    Rob43
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,148
    Tampa, FL
    That sounds very likely. I would not be surprised that some ports have been damaged by bad EVSE designs. And the blending of stories, while not usually deliberate, happens quite often. We've probably all gotten our memories mingled like that.
  7. Bill Norton
    Bill Norton Senior Member
    2,145
    734
    MONW, Ks.
    I've had to 'extract' an out of place 'O-ring' assembly on a public Chargepoint charge handle with my car's flip-out key.
    It was keeping the handle from being inserted all the way into the car port.
    ChargePoint probably uses cheap chinese parts.
    Note: Everything is now 'cheap chinese parts'.
  8. Nuclear_Charged
    Nuclear_Charged New Member
    Ontario
    2020 Prius Prime
    Upgrade
    i dont know, inform me
  9. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    Got a new grill a while back. Silk Blaze E706CA7F-DC2E-40FF-83FE-5170E94BEA1D.jpeg
  10. Jon Bloom
    Jon Bloom Member
    77
    78
    Connecticut
    Installed the OEM roof rack.
    Now if USPS would just deliver the bike rack to go on it I'd be all set.
  11. hermosa007
    hermosa007 New Member
    Hermosa Beach
    2020 Prius PHV
    TGrracie and Raytheeagle like this.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Shiny:).
    Mind sharing the cost and maker:whistle:?
    Might need to do a similar activity soon(y).
  13. hermosa007
    Hermosa Beach
    2020 Prius PHV
    Im in Socal. I have a guy that does it. Best in the business.
    His Instagram. mikes.mobile.detailing
    He has a shop and is also mobile. I paid $450.00, 2 year guarantee. Ceramic is amazing.
    Never have to wax. Looks wet all the time.
    Kayley and Raytheeagle like this.
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    That sounds like a great deal:).
    I'll look locally up here, but which ceramic does he use:whistle:?
    Thanks for sharing(y).
  15. hermosa007
    Hermosa Beach
    2020 Prius PHV
    You would have to ask him. I sent you his contact. You won't regret.
  16. jerrymildred
    11,517
    14,148
    Tampa, FL
  17. correctclick
    correctclick Junior Member
    37
    VA
    2020 Prius Prime
    Which rack did you install? Can you please share the part number? I see two different numbers PW301-47005 & PW301-47009. Not sure which one would fit a 2020 Prime.
  18. Jon Bloom
    Jon Bloom Member
    77
    78
    Connecticut
    I ordered the rack from ToyotaPartsDeal.com, and when I ordered it it said it was the PW301-47005 but what was delivered was the PW301-47009, which fit just fine.
    According to the Toyota parts site, the -47005 has been replaced by the -47009. Anyway, I had no difficulty installing the -47009 part. That site also gives lists of the vehicles the parts fit.
  19. Mark57
    2,945
    2,740
    OK
    Today I yanked out my wimpy Prius horns and put in new
    72102 FIAMM Freeway Blaster Horn High Tone
    72112 FIAMM Freeway Blaster Horn Low Tone
    Ohhhh, how sweet the sound . . . . . It actually sounds like a car horn. Not bad for ~$24 grand total from Amazon and 30 minutes labor.
    I put in the first one and tested it just to see if it worked. It really sounded weird with one original and one FIAMM. :p The second FIAMM fixed that.
    Kayley, m.wynn, Raytheeagle and 3 others like this.
  20. jerrymildred
    11,517
    14,148
    Tampa, FL
    I keep thinking about that. Those are the same horns I had on my last three motorcycles. They WILL wake up an inattentive driver. :D
    In fact, I think you just pushed me over the edge. LOL!
    Edit to add: Yup over the edge. Due to arrive Thursday.
    Question, @Mark57 -- Did they work OK without a relay? I had to use a relay on the motorcycles. I haven't looked yet at the car wiring to see, but I'd think it should handle 12A with plenty to spare. I have relays and wire, so it wouldn't be a big bother if I need them.
    #180 jerrymildred, Mar 3, 2020
    Mark57 likes this.
