Noisy 2017 Prime heat pump
Discussion in 'Prime Technical Discussion' started by tedjohnson, Jan 5, 2020.
  1. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    My 2017 premium 46Kmi has a pretty noisy heat pump. You can sure hear it compressing the gas, Its louder than the ICE is. Anyone else observe this? Thanks.
  2. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yup! It is rather noisy. The only time my ICE sounds louder is when I floor the accelerator in HV mode. The heat pump gets noisier when the temperature goes lower.
    iPad ? Pro
  3. CharlesH
    2,796
    1,163
    Roseville, CA
    Why would the heat pump be louder than the A/C (cooling)? It's the same compressor with the refrigerant moving along the same path in both cases. The only differences in heat pump mode are the damper to the interior condenser being open and the exterior coil being used as an evaporator (cold coil). I am not claiming that there isn't a difference, just wondering how.
  4. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Thanks, was wondering if mine had a problem, guess not....Just bought the car used and never used the cooling yet, but thought the heating function might be quieter for some reason.....
  5. bisco
    51,861
    idk, noisier than the ice sounds too noisy to me. can you post a recording?
  6. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Humm, I don't even know what the heat pump sound is like. Can you hear the sound in the cabin while driving?
  7. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Actually not a lot. I can hear it better outside the car than while driving. I actually hear the fans more inside the car.
    Unsupervised!
    Salamander_King likes this.
  8. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Yes it is noisier than the ICE is, unless you floor the throttle then the engine becomes noisier than the heat pump as drash above says his is....
  9. Salamander_King
    11,016
    8,948
    New England
    Well, I can't say I noticed any regular noise louder than ICE while driving my car with windows down. The blower fan if it is set to HIGH may be louder than ICE but that is true without heat pump on. I have been trying to figure out a way to tell when the heat pump comes on, but so far I have not found a easy sign that heat pump is on on my car. If the noise is more on outside of the car, then I have not tried listening the sound while car is on and I am outside.
    #9 Salamander_King, Jan 6, 2020
  10. bisco
    51,861
    same in the pip (a/c only). pretty quiet inside the car windows up. loud buzzing outside.
  11. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    I can't hear the heat pump during driving - there are other noises that are louder to my ears.
  12. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    Carista has a "quiet" mode that you can set for the heat pump. I have no idea what it does, but the noise doesn't bother me, so I'm not going to try it.
  13. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    One thing i have noticed is i can definitely hear the heat pump when i slow down quickly .. like stopping at a red light. I mean the road noise is enough to cover the heat pump when i drive but i when i slow down i can hear it going from loud to almost silent .. then as my speed goes up i can hear ramping up until the road noise cover it again. I have seen this Carista "quiet" mode in the app ... is not activated on mine and never tried it yet ...
  14. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    I was locking up last night and opened my door to the garage to make sure the garage door was down. I heard this loud buzzing and thought it was our freezer out there. Nope, just the car sounding like a buzz saw. Freaked me out a little bit then it stopped after a minute or two.
    iPhone ?
  15. bisco
    51,861
    evap check
  16. BobB5623
    BobB5623 New Member
    My 2017 Prius Prime had the same issue at 30K. They replaced the electric compressor and the noise went away. I have a feeling the compressor is undersized for the duty. I would encourage anyone else with this problem to let their dealer know.
