Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Mendel Leisk
    40,467
    Those are EGR passageways, basically the end of the EGR circuit. Have you cleaned the EGR?
  2. Eddie25
    Eddie25 Active Member
    482
    202
    MI
    Yep, about 4,000 miles ago.
  3. Harry9508
    Harry9508 Junior Member
    46
    24
    Gilbert Arizona
    Update: After some 200 miles, these are the things I noticed:
    1. My exhaust tip is extremely clean now, no carbon, no soot. (It had a lot before)
    2. My engine knock has gotten worse.
    3. There's still oil pooling in my manifold.
    4. There's like teeny tiny improvement in mpg. I think
    I am gonna start the intake job in a couple of hours. Hoping the knock vanishes after that.
    Originally, I experienced a knock if I prematurely shut ICE down on a cold start up without letting it get warm enough .
    Now basically, on every cold start, it's there and doesn't go away until I accelerate it a bit and then let it get warm with the accelerator pressed.
    And even after the engine is warm enough, when ICE kicks in at idle state, there's a very short knock for a split second.
    P.S has any one got an OCC with a dipstick in it? I removed it while the engine was running and it started knocking the exact same way it does on a cold start, so I quickly put it back inside the OCC, FYI it had a vacuum which sucked the dipstick back inside itself.
    #1583 Harry9508, Jan 5, 2020
    NickHall834 likes this.
  4. Harry9508
    46
    24
    Gilbert Arizona
    Intake just has one inlet from the EGR. Which passageways are you talking about?
    I'll check these out while I clean the intake, if they are dirty I might clean the EGR too but if they ain't I should save the trouble
  5. Eddie25
    482
    202
    MI
    Each of the 4 large openings on the intake manifold (that go to the cylinders) has it's own little hole that apparently carry the EGR 'air' (AFAIK), therefore tend to foul up... as was the case with mine.
    SFO likes this.
  6. Harry9508
    46
    24
    Gilbert Arizona
    Yep! Damn I am noticing these for the first time LOL.
  7. Mendel Leisk
    40,467
    This is mine, having an Oxi-Clean soak:
    (Having the EGR pipe attached, I put a funnel in it, for pouring in the Oxi. Need to put stoppers here and there.)
    Each port has an EGR outlet, #4 flagged here.
    The Oxi action is creating these columns of foam:
    One shot where it's not buried in foam:
    Robert Holt, Harry9508 and Rebound like this.
  8. HappyDad701
    HappyDad701 Junior Member
    Colorado
    Here's my contribution to the oil catch can installation. I drilled a hole in the catch can bracket, and used a 1/4-20 bolt and nut to secure it to the car's frame (cyan arrow). There's already a hole of the right size on the frame, so it's a no-brainer. Want to also thank all who contributed to the thread to make this relatively straightforward.
    From the top of car:
    Bottom of car:
  9. Harry9508
    46
    24
    Gilbert Arizona
    Thanks for the info!
  10. NickHall834
    NickHall834 New Member
    virginia
    harry, I’m in the same boat as you are right now. I’m about at my wits end with my car over this. It knocks no matter what I do.
  11. Harry9508
    46
    24
    Gilbert Arizona
    Ya man same here. It's knocking so badly! I just either put it into N (neutral) or start driving it instantly to avoid the knock on a cold start. And ya, it's strange it only knocks on P or D when it's charging the battery. I don't how everyone else solved their problem LOL
  12. ASRDogman
    ASRDogman Senior Member
    7,115
    3,713
    Maybe you have a leaking injector allowing fuel in the chamber and it's igniting???
  13. Harry9508
    46
    24
    Gilbert Arizona
    You should check your spark plugs for that!
  14. ASRDogman
    7,115
    3,713
    Depends on how bad the leak is. If the injector is dirty, it wouldn't always leak.
    When it's cold, the fuel with sit.
    But then driving it would even out and the plug wouldn't be black.
    If they are dirty, the spray pattern will not be misty, there could be a stream,
    which would cause the fuel not to burn evenly or completely.
  15. Harry9508
    46
    24
    Gilbert Arizona
    So how should one diagnose it?
  16. NickHall834
    virginia
    Are you getting and codes? I’m getting a cylinder 2 and 4 misfire codes
  17. Harry9508
    46
    24
    Gilbert Arizona
    No, no codes here. Nothing strange at all, just the knock whenever I start the car when it's cold. It knocks for 2,3 minutes until unless I press the gas pedal or shift it to N
  18. Harry9508
    46
    24
    Gilbert Arizona
    You should check your spark plugs and your coils.
  19. ASRDogman
    7,115
    3,713
    You have to remove the injectors and hook up a hose with a pressurized tank so you can watch the spray.
    Reading back over the posts I noticed you haven't cleaned the intake manifold. Have you done that yet?
    You said you got knocking when you removed the dip stick of the occ. You could have a vacuum leak.
    Have you checked all the connectors?
  20. Harry9508
    46
    24
    Gilbert Arizona
    I was supposed to clean the manifold yesterday but I couldn't. I am gonna do that soon. Okay, yeah so how do I figure out the vacuum leak first? Is there an easy way to check for a leak?
