Throttle body gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bbonez, Jan 14, 2020.
  1. Bbonez
    Bbonez Member
    40
    44
    I purchased a Fel-pro intake manifold gasket and it came with a throttle body gasket as well, the throttle body gasket has a little metal screen attached.
    Has anyone used this style gasket? I'm thinking about just reusing the original TB gasket.
  2. Eddie25
    Eddie25 Active Member
    482
    202
    MI
    I tried to and it didn't work. The screen doesn't allow the gasket to sit far enough down in the slot. I reused the old one, which was fine. All the intake gaskets still looked new after 140k.
    Raytheeagle likes this.
  3. Mendel Leisk
    40,467
    I vaguely recollect this came up before, the gasket having a little net. But can't find it. Seems like the stock gasket is readily available, and cheap:
    Toyota Prius Throttle Body Gasket
    I was just cleaning my intake manifold, at (low, I know) 85K kms I reused all gaskets, they looked ok. Did take them all out, clean the grooves, and wipe down the gaskets.
  4. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    for normal the mesh is used to calm down the airflow (reduce turbulence) /
  5. Seymour1
    Seymour1 Member
    240
    27
    So, what does "reduce turbulence" mean to me for the modified throttle body gasket? More power, more MPG, less maintenance?
  6. ChapmanF
    17,186
    There was an intake manifold revision, and if I remember that thread right, the meshy gasket will fit on the newer manifold, but not on the older one. A plain gasket will fit on either manifold.
    I've yet to see anybody offer a clear, substantiated explanation of what the mesh is there for. I'm sure there is one, that could be found with enough time in the library. I haven't searched hard enough either.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    Probably their updated version of an OCC.
  8. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    For those not running an air filter, it minces the incoming bugs into Itty bitty little pieces to prevent engine damage.
    SM-A536V ?
    #8 mjoo, Apr 17, 2024
  9. douglasjre
    douglasjre Senior Member
    2,087
    698
    Null, NL
    You also need to replace the gasket for the EGR pipe and a PVC valve while you're there
