Inverter just blew, 3K out of warranty!!......
Discussion in 'Gen 3 Prius Main Forum' started by AEC916, Jan 21, 2020.
  1. AEC916
    AEC916 Junior Member
    Sacramento, CA
    Just found out the inverter blew on my 2010 with 153k miles and the shop wants $2,900 to replace it. The CA warranty on it was extended to 150k miles and the stealership said no go. Any thoughts on trying to take it up with a regional at Toyota? Or any other Ideas besides spending nearly $3k on a car I was planning on selling this summer. Appreciate your input.
  2. 3PriusMike
    3,097
    2,419
    Silicon Valley
    Realistically, if you were the original owner and had 149,999 miles and something under warranty broke and you got a free replacement, then you might think you won the lottery because something that you got 99.999% of the guaranteed use plus a new whatever which should last another 150K miles!
    Instead its like you lost the lottery...no big deal just a $1 ticket.
    Of course the $2900 is painful and good for you if you can get Toyota to pay for it...but then what is the limit? 4K miles over the number? 5K, 10K? Don't they have to set a limit somewhere?
    Mike
    AEC916 likes this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Used inverters are plentiful on ebay. Buy a used one and install yourself...they are not expensive.
    On a semi-related note, it is interesting that non-CARB Prius receive 15 yrs/unlimited mileage for the common inverter issues while the CARB approved ones are limited to 15/150K:
    https://static.nhtsa.gov/odi/tsbs/2018/MC-10145758-9999.pdf
    RMB, SFO, AEC916 and 3 others like this.
  4. Leadfoot J. McCoalroller
    8,017
    7,493
    Pennsylvania
    2018 Prius c
    ^ That. A secondhand inverter installed by an independent mechanic is the appropriate repair for this vehicle.
    Taking any 10+ year old car to the dealership is like begging for a bank account beat-down.
    RMB, AEC916, Merkey and 4 others like this.
  5. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    Find a Prius with 149,000 miles, install your blown inverter in it, and take it to a dealer.
    Just kidding... you’ll want to pull one from a wreck, etc.
    RMB and AEC916 like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,517
    Bay Area, California
    2019 Prius Prime
    Since your in Sac, check out the auto recyclers in Rancho Cordova;).
    They have plenty of stock:).
    Swap the inverter out for fractions of the dealer quote and be back on your way(y).
    AEC916, 3PriusMike and fotomoto like this.
  7. ETC(SS)
    7,070
    Pends....
    You actually have a few options.
    1. You can try for a good-faith warranty adjustment from Yota.
    For a ten-year-old car that is most of the way through its design service life, it would require MUCH goodness and faith but it costs you nothing to try.
    2. Used inverter installed either DIY or by an independent wrench.
    This will probably cost you 1/3 of your car's real-world value, but you'll have the opportunity to sell the car and get another one this summer after the tax-refund feeding frenzy is over with and the dealers get hungry again.
    2a. Used inverter installed either DIY or by an independent wrench....and drive the car for a while longer.
    3. Sell the car As is - where is.
    You'll probably get close to the real-world value minus what it would cost you to repair it.
    3a. Talk to a dealer about trading the hulk in.
    Perhaps instead of eating their cost for another inverter (probably about $500 for them) they would be willing to cut you a deal on a replacement. I do not personally think this is a WISE option....but it is an easy one to take.
    Good Luck!
    AEC916 and Merkey like this.
  8. psusi
    psusi Junior Member
    68
    24
    Orlando, FL
    The traction battery went out on my 2008 2 years ago. The dealership wanted $3600 to replace it. Following the advice here on the forums, I complained to corporate and they ended up covering half of it, which made me pretty happy.
    RMB, AEC916, Merkey and 1 other person like this.
  9. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    I can't understand the rationale behind this. I'm glad I have the longer warranty, though.
    The Critic and AEC916 like this.
  10. Tim Jones
    Tim Jones Senior Member
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    My inverter went out at 196,000 and toyota gave me a new one installed free.... 2013 prius v.........pretty sure yours is covered....miles don't matter.... 15 years.
    pjksr02, SFO and Merkey like this.
  11. The Critic
    3,193
    2,330
    CA
    Did you miss the post above you?
    iPhone ? Pro
    Raytheeagle likes this.
  12. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    no
  13. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    what am I looking for?
  14. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    guess i missed something.......?
  15. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    oh.... the pdf........just seen it.....
  16. Mendel Leisk
    41,012
    If you DIY or work with an independent mechanic, here's some repair manual info, inverter replacement:
  17. The Critic
    3,193
    2,330
    CA
    Hmm, I re-read the bulletin. The asterisk is in reference to the original warranty terms; the bulletin goes onto state 15 years/unlimited mileage.
    OP, I think you should have your dealer re-confirm. This might be a covered repair if your fault codes match the ones described.
    pjksr02, RMB, m.wynn and 2 others like this.
  18. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    Same thing happened to me... I was 1100 miles from home. Dealer told me $3700 or more. Thanks to RJ Parker he sent the info to me and I presented to dealer and it was covered. And they are supposed to tow and give loaner car.
    I even got a unit from wrecked car and swapped it out and it wouldn't start.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    IMO you have nothing to lose in calmly and sanely, contacting Toyota Care--and asking if any "Goodwill" extension could be obtained or applied.
    You've already been told No by the dealership...the worst would be Toyota comes back and confirms the No. The flip side is I have read posts where occasionally Toyota say's Yes, in various different scenarios.
    So I would I try.
    With very tempered expectation just because the reality is, if you're past warranty, you're past warranty. Toyota doesn't HAVE to offer any support.
    Then if you get a Yes...evaluate the value, depending on what level of support...pro-rated or otherwise.
    If you get a No, and your plan was/is to sell in months? All the advice about finding a used inverter would probably be the way I would go.
    Unfortunately, as would be with any used vehicle, if it's not running for any reason, the value plummets. So it would be in your advantage to try to find a semi-economical solution to at least be able to sell the Prius as a running Prius with a working inverter.
    You'll have to look up similar Prius used car values, and do some math, to find out where that line is.
    mikey_t and Mendel Leisk like this.
  20. psusi
    psusi Junior Member
    68
    24
    Orlando, FL
    Has toyota drastically extended the warranty? On my 2008 it was 10 years in CA and only 8 everywhere else.
