Throttle And Oil Codes After Cleaning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuslover09, Jan 25, 2020.
  1. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Got theses codes after cleaning the dirty oil and dirty throttle in my Dad’s 2004 Blue Prius.
    P0301 P302 P0303 P0304 P0305 P0306
    P0307 P0308 P0309 P0310 P0311 P0312
    P0313 P0011 P0014 P0018 P0022 P0023
    Any ideas? My dad and I cleaned the oil and throttle 3 hours ago
    #1 Priuslover09, Jan 25, 2020
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    The car just got an oil change and the brakes replaced at Jerry’s Toyota in overlea md where the car was bought in 04
    #2 Priuslover09, Jan 25, 2020
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    The car has 300.098 miles
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    The car has the red triangle and the Maintenance light on
  5. Washingtonian
    Washingtonian Senior Member
    726
    621
    Kind of interesting, but I don't see the relevancy of fault codes from an 04 Prius with 300K miles being posted on a forum for 2017 and newer Prius Primes.
    Priuslover09 likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,136
    Tampa, FL
    Gen 2 Prius owners are probably not watching the Prime forum very closely. Hit the "Report" button and ask a moderator to move this to the proper forum. You'll get better and quicker help there.
  7. Trollbait
    12,312
    You can google the codes. Most are an open standard, and some won't apply; the computer seems to generate multiple ones for one issue.
    The three I checked were misfires in cylinders 1, 7, and 9. Obviously, there are only 4 cylinders.
    When was the last time the spark plugs were changed? They are the first thing to check for a misfire.
  8. Mendel Leisk
    40,465
    How'd you clean the throttle body? Carb cleaner spray can sprayed into the throat? It's safer to just spray a shot onto a shop towel and wipe down the barrel interior and blade. You can do a better job if your remove the bolts/nuts, lift the throttle body right off (leave coolant lines attached, and clean from both sides.
    Not sure what you mean by "cleaning the dirty oil". Again, what were you using, and where?
    #8 Mendel Leisk, Jan 26, 2020
  9. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    That's a lot of codes:cool:.
    Was anything electrical disconnected?
    Is everything plugged in and have checked?
    Does the car even get to "ready"?
    If it does get to "ready", what does it run and sound like?
    Was the orange safety plug pulled and is it properly seat?
    Good luck and keep us posted(y).
    SFO, Priuslover09 and Mendel Leisk like this.
  10. Mendel Leisk
    40,465
    Or clamp not tightened up, say on the throttle body air intake? There's also a gas tank vapour hose: it's pushed back on ok?
    Priuslover09 and Raytheeagle like this.
  11. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    The car goes into ready the smart plugs were replaced in 2018 of December
  12. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I was cleaning dirty throttle and the dirty oil
  13. Mendel Leisk
    40,465
    Got that. How, specifically?
  14. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    By cleaning it that’s how
  15. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I used a wet sponge and a dry rag if that’s what u mean
  16. Mendel Leisk
    40,465
    Did you spray carb cleaner directly into throttle body throat?
  17. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    No I used a wet sponge and a wet rag
  18. alinica2001
    alinica2001 Member
    94
    Romania
    did you check for DTCs BEFORE doing this cleaning?
    I would try to erase all DTCs and see if any new DTCs are coming up after that.
  19. Mendel Leisk
    40,465
    On the throttle body? Wetted with water? on the outside or inside?
  20. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Inside
