Help! Green Fluid Leak
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 3Pri_Baker, Jan 27, 2020.
  1. 3Pri_Baker
    3Pri_Baker New Member
    Vacaville, Ca
    Hey All,
    I have a 2011 Prius 5. This morning I saw what appears to be a large leak coming from the driver side front tire area. The fluid is a clear / green ish fluid. However, when looking at the coolant reservoir - the fluid in the reservoir is a pink color. Im not sure wether the radiator is leaking or what it might be. Any suggestions?
  2. ChapmanF
    18,094
    There are two coolant reservoirs. Are both of them filled with the correct pink stuff?
    Green....
    Could your car be a Skrull, impersonating a Prius?
    Serenity and Rebound like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    A possible cause is brake fluid, especially being near a wheel. Check your brake fluid reservoir.
    I know green is odd, but I've seen many Prii with green brake fluid. Many people suspect it's due to air contamination of the brake fluid, others suspect it's due to copper exposure from the sealing rings used in the system. Regardless, there's a bunch of cars running around with (previously) clear brake fluid that now has a green color to it.
    It's at least worth checking out.
  4. gliderman
    gliderman Active Member
    751
    225
    Have you washed your car lately? What color is your window washer fluid? Mine is green.
  5. Patrick Wong
    18,200
    6,501
    Perhaps a dog took an unusual interest in the tire?
  6. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    and if you find him/her/it, please take it to a vet immediately........any green stuff exiting any urinary tract warrants being diagnosed and treated, even for a dog, lol.
  7. Mendel Leisk
    41,340
    Ever had the vet request you catch some of your dog's first-of-the-morning pee? Good thing I was wearing short sleeves, that's all I've got to say...
    jerrymildred likes this.
  8. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    Did you park over somebody else's coolant leak mess? Uh, was the tire "patched" at one time with that Green Slime stuff that now has decided to start leaking out? Is your use of the word "large" refer to the area affected or rate of flow?
  9. ASRDogman
    ASRDogman Senior Member
    7,549
    3,897
    Did you run over a Vulcan????
    Rebound, TMR-JWAP, Grit and 1 other person like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Now how are we supposed to get that image out of our heads??!! :ROFLMAO::ROFLMAO::ROFLMAO:
    Anyway, back to @3Pri_Baker, it sounds to me like brake fluid that's turned green, but that might depend on the definition of "large." The washer fluid tank is over on the passenger side in Gen 3, but I guess it might find a path over to the driver's side.
    When you said the coolant reservoir had pink liquid in it, I'll guess you meant the inverter coolant? You also said you wondered if the radiator was leaking. That's also supposed to be pink but someone might have put in the wrong stuff. What color is the liquid in that tank?
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    At least you don’t eat corn flakes every morning like I do.
